I’m just about at the end of my tether with the Shimano Hydros on my Arkose.
They were alright for the first few months (brilliantly silent) but now howl every time I make a hard stop.
I’ve cleaned everything with alcohol.
I’ve ‘deglazed’ the pads by rubbing them on fine sandpaper.
I’ve removed the discs and sanded off the previous braking marks (as recommended in an article I read by the Avid brake designer)
after cleaning up pads + discs I’ve ‘bedded them in’ properly (repeated hard stops from 15-20 mph)
I’ve come to the conclusion that the pads might be contaminated (don’t know how this would happen front + rear – I’m really careful not to spray any lubricants near the brakes)
I don’t see why I need to replace the discs – they’re not warped, and if I give them another light sand off before fitting new pads nothing can be wrong with them.
I’ve got Shimano Deore hydros on my MTB which never squeal, and neither did the Formula brakes I had before.
So what pads should I buy? – not bothered about cost or longevity – just performance and quietness (the bike does about 1k miles per year on road/towpaths)
What else should I try?
Cheers in advance…
