Another vote for the Meaco! It was a bit more than I was willing to spend but now I’m very glad I did, very highly recommended by me after going through a few cheaper fans over the years that where either underpowered or noisy.
The Meaco is very quiet so you can keep it on while sleeping and can shift a lot air if required and I quite like the vertical and horizontal oscillation function. I like the way it bounces air around the room so even if the fan isn’t directly on you can still feel a secondary breeze.
I went all out and got the pedestal version, not really sure its worth an extra £40 over the table top one that is the same size. I’d rather save £40 and stick the table version on a small side table or stool.
My top tip: I move the fan to the bedroom ~20mins before bed time. I place it front of the open window and set it too max and it sucks in cooler air from outside and displaces the warmer stale air inside. I can genuinely feel the air temp in the room is cooler. Then when actually going to bed stick the fan on lowest setting and point it at the bed. Its super quiet and gives just enough gentle breeze to cool you.
