The pay as you go electric key meter (Actaris ACE900 kbp) is not working correctly, not giving any info in screen, back light is working, button does bugger all (can’t see how much etc) but Electric (day rate) is still working. (night rate that does hot water and storage heaters, seem to have stop working/supplying power at night, but need to double check fuses just in case)
So I rang the supplier (Spark elec – set up by past tenant) so after a bit of getting pushed about from one person to another.
I finally get told a Elec engineer can’t do anything TILL MY POWER goes out!!
as it might hurt them!
Is this right?
Surely they can pull the fuse/turn off the incoming power, pretty sure the meter/box doesn’t hold any/a lot of power, just seems a lot of crap, more so it could be days or even weeks before that might happen, where I have no heating or hot water.
When I explained this, they couldn’t care less, just keep saying call back when power goes out!!
And you can bet that be in the evening when in the middle of cooking dinner!
So is it true, a electrician can’t work on a pay as you go box, if “power” is going to it?
Thanks
