Home Forums Bike Forum Durace bar end shifter, Xt sti's, same cable pull?
Viewing 14 posts - 1 through 14 (of 14 total)
  • Durace bar end shifter, Xt sti's, same cable pull?
  • ton
    10 spd bar end shifter, 10 spd sti’s, are they the same cable pull.
    I thought they were, but cant get em to sync.
    thisisnotaspoon
    DA 10 speed was the same cable pull as an MTB 9 speed mech (so works with a 9s mech and 10s cassette), but not a 10 speed MTB mech.
    Duc
    Different mate. I think Charlie has some bar end ones that will work from Microshift but could be wrong
    simondbarnes
    No, they’re not. The 10spd DA bar end shifters will work with a 9spd mtb mech, not a 10spd.
    ton
    so if I have just fitted 10 spd durace bar end, to a xt 10 spd block and mech, it wont work.
    what do I need?
    so I need a 9spd block and mech…………aaaarrrrgggghhhhhhhh
    simondbarnes
    There is another way. There will be one of these that will do the job…
    Shiftmate
    Edit…
    A #6 will do the job…
    Shiftmate 6
    otsdr
    thisisnotaspoon
    No, just a 9s mech, it’ll still be 10speed it’s just the pull ratio in 10s mechs that’s different.
    kilo
    Have you checked to see if the shifter can be changed to friction rather than index, iirc some of the older ones can by moving an adjuster
    cp
    DA bar end shifters can be operated in friction mode, so no indexing, you just move the lever enough to operate the mech. You quickly get used to how much to move the lever.
    wzzzz
    Three options to go with your 10spd road shifter and 10 spd mtb cassette in order of extra expense:
    [list]
    [*]Drill a hole in the arm of your 10spd mtb mech to route the cable and change the pull. http://www.huckingkitty.com/forums/viewtopic.php?f=9&t=868[/*]
    [*]9spd mtb mech (no chance of a clutch)[/*]
    [*]Tanpan http://www.wolftoothcomponents.com/collections/derailleur-optimization/products/tanpan[/*]
    [/list]
    I’d do the first.
    ton
    9 spd mech on its way from wiggle.
    i hate bikes………..sometimes.
    scotroutes
    Bugger. I could have given you one!
    Pickers
    You’d have to stand on a box!
The topic ‘Durace bar end shifter, Xt sti's, same cable pull?’ is closed to new replies.
