- This topic has 54 replies, 25 voices, and was last updated 5 years ago by mattbee.
Dropper on XC bike – side-effects
molgripsFree Member
Just fitted one to my XC race bike after thinking I didn’t need one. The kind of riding I was doing on it didn’t merit one, however after exploring a load of new trails on my big bike I realised I could much more easily do them on my XC bike too if I had a dropper.
So I’m now the proud owner of a Specialized Command Post which is a bit strange being mechanical and all, but I’ve realised some interesting side effects for XC bikes. I’d previously put the bars a bit higher than I really liked for climbing because it made it too front-heavy when descending. But of course now I can slam the bars because whenever I get to something steep I can drop the saddle. Haven’t ridden it yet so I’m waiting to find out what it’s like on single track with my whole CoG lower.
mikewsmithFree MemberHaven’t ridden it yet so I’m waiting to find out what it’s like on single track with my whole CoG lower.
You CoG will be lower.
kiwijohnFull MemberI would if I could.
Too used to it on the big bike, now the xc whippet feels so clumsy.
Kryton57Full MemberI get to something steep I can drop the saddle
And how’s your knees, hips, lower back and power output going to be after riding a dropped saddle when climbing?
DrPFull MemberI guess he paid extra for one that goes ‘up’ as well as down????
DrP
Kryton57Full MemberI’d previously put the bars a bit higher than I really liked for climbing because it made it too front-heavy when descending. But of course now I can slam the bars because whenever I get to something steep I can drop the saddle.
Read in context it sounds like he’s putting the saddle down when climbing. I may of course be wrong.
molgripsFree MemberRead in context it sounds like he’s putting the saddle down when climbing. I may of course be wrong.
Steep down, I meant.
I posted the thread for the benefit of those who might be thinking they wouldn’t benefit from a dropper, because they think they are for gnarly tech riding. But there are other benefits than simply getting your bum on the back tyre.
DelFull MemberRead in context it sounds like he’s putting the saddle down when climbing. I may of course be wrong.
read in context it sounds like he has his bars set higher than desirable for descending. there is no reference to saddle height for climbing.
TrimixFree MemberThe other side effect you may discover is cornering speed will go up.
Fast tight corners with the saddle down will let you really lean the bike over much more than when the saddle is up. For racing mates on the twistys it works well. You can get away with daft lean angles, or low side off the trail trying 🙂
40mpgFull MemberQuicker starts with the saddle down too as you can position over the seat ready to sprint. Just click it up once you’re moving
jonnyboiFull MemberI think its a good upgrade for an xc bike where things get technical, if you are running short travel and a steep head angle you are going to be up against it anyway, so anything that helps give a bit more control and stability is a good thing
ayjaydoubleyouFull MemberI posted the thread for the benefit of those who might be thinking they wouldn’t benefit from a dropper, because they think they are for gnarly tech riding. But there are other benefits than simply getting your bum on the back tyre.
Don’t just use them for the few steep sections per lap, any time you are stood up and aren’t pedaling, the seat should be down.
Its not the 90s anymore, Watch some WC races, aside from a couple of super tech bits, they aren’t bum on tyre, with dropper or without. Central weight and relaxed arms and they are flying down things us amateurs wouldn’t do on an Enduro bike.
OnzadogFree MemberWasn’t it CP back in the Mojo days who tested droppers on XC race bikes?
I believe it went something like this…
CP – see, it’s faster with a dropper.
XC racer – yeah, but it’s heavier.
CP – yes, but it’s faster.
XC racer – but heavier.
CP – They don’t give out prizes for the lightest bike.
XC racer – true…but it’s heavier.
CP – %@#£
geexFree MemberAnd how’s your knees, hips, lower back and power output going to be after riding a dropped saddle when climbing?
Stronger than a bloke who sits in his house on a bike 3 times a week “training”
Droppers actually made me weaker. I used to do 2hr+ XC rides on dirt jump bikes with the saddle slammed the entire ride.
RamseyNeilFree MemberGeex you are by a large margin the most awesome person on this forum .
DanWFree MemberIt is a great observation OP as I found exactly the same thing, especially on a HT where the bar height is somewhat dictated by going as low as possible but not so low you risk going arse over tit on steep stuff when the forks go in to their travel. It only took a ride or two before I also lowered my bars and found it much better. Droppers make better climbing XC bikes! 🙂
I feel that the 65mm Lev Ci I have is more than ample on an XC geo frame and bizarrely feels too much for most situations. You don’t need to drop the saddle much to get a bit of help and the traditional XC geo kind of dictates where your body position will be relative to the wheels so you don’t get the same kind of benefit as a more Endurbro bike with longer drops.
My overall feeling was that a dropper didn’t make me any faster but it did open up certain lines I wouldn’t have ridden before as that “ah sh1t I’ve cocked that up” moment is a little further away. Same with taking on certain lines when it is really greasy.
greyspokeFree MemberStronger than a bloke who sits in his house on a bike 3 times a week “training”
Actually ordinary posts can be adjusted during a ride, you didn’t need to buy a dropper for that.
qwertyFree MemberIIRC Bart & Rob commented on this, saying the main benefit for XCO pros was better recovery / lower heart rate on the descents before the next climb.
molgripsFree MemberIt’s the 100mm Command Post IR with 100mm drop. Being mechanical rather than hydraulic to save weight on oil (it’s 480g) it has indexed positions. First click is about 25mm, then there are a load of micro clicks over the next 30-40mm then one more all the way down.
In practice it’ll be dropped a bit, or dropped all the way.
TurnerGuyFree MemberXCP has one drop position – 35mm – sweet – just right for XC and super fast toggling between positions with the SRL lever which is just like a right gear shifter.
molgripsFree MemberI have the SRL lever, which is indeed really nice. However I quite like the 100mm drop as I use the bike for general riding as well as XC racing (this is a lie, I haven’t XC raced since 2010)
molgripsFree MemberWell that was dramatic. Because the bars were lower and now the saddle, I could get much lower on the bike which made it FAR more manoeuvrable on twisty singletrack and far more secure at speed. Lots more fun. Also easier to pop off stuff with more space underneath me.
However the lower bars put a bit more pressure on my hands. May have to work on that.
SaccadesFree MemberHad a dropper (125mm reverb) on my xc/marathon machine for 3-4 years, brilliant for 12/24 hour events as you get a wider range of positions to keep comfortable.
Much faster and in control on descents on shorter courses too.
molgripsFree MemberAlso, I had set the forks quite firm to reduce dive and make it more secure on steep stuff – it’s has a steep head angle. But now it’s far less of an issue so I let quite a bit of air out of the forks and the ride is far smoother at speed.
metalheartFree MemberI’m a recent dropper adderer. Avoided due to every Reverb ever failing after, oh, 10s 😉
Its not been the ‘game changer’ I was expecting tbh. Where I find most of use is being able to hike it up for climbing, that’s awesome (helps my knees!). I only drop it fully very occasionally, probably not riding rad or gnarlly enough (I take too long to heal when I break these days).
i reckon I could problem get away with a 35 or 50mm dropper (so only 100mm extra I’ve paid for then 🤣).
god, I don’t half miss it on the Sherpa though.
hols2Free MemberIts not been the ‘game changer’ I was expecting tbh.
Wait till you try to go back.
molgripsFree MemberI only drop it fully very occasionally
Likewise, but the main benefit at least on XC is as you say, the partial drop. Being able to get my body lower really helps thread the bike through singletrack. But you have to be pressing on for this to be a benefit, i.e. trying to go as fast as you can. If you’re just chilling out it won’t make much difference.
A legitimate use case – I think Specialized make a 35mm one don’t they for XCers?
Another advantage on yesterday’s ride: I can get far more clearance when getting emergency air to clear an obstacle; and when getting recreational air I can control the bike much better so now I go looking for it far more.
I was adverse to dropper initially because of the extra weight* but it’s well worth it.
* Previous carbon post 260g; previous alloy post: 270g; lightest carbon post available 205g; Specialized command post IR 100mm 480g not inc remote.
TurnerGuyFree MemberA legitimate use case – I think Specialized make a 35mm one don’t they for XCers?
your memory seems worse than mine, you appeared to anyswer a post of mine in which I mentioned it, and the SRL lever that you then said you had!
The advantage of the 35mm is that it is the full drop postion, so faster to confirm it’s position, so you can toggle up and down fast witht he SRL lever, so even at Swinley it gets used a lot as up for the small climds and then down to cruiser, then back up for the next short climb, etc.
Been having some issues with my right knee so getting so easily to optimal climbing position is nice, then back down to cruiser for some manouverability.
hols2Free Memberi reckon I could problem get away with a 35 or 50mm dropper
I started out with a 75mm GravityDropper back when they first came out. It was a game changer so I got a 100mm one for my other bike. Could never understand why people felt the need for more than 100mm drop, but then I got a 125mm Reverb. At first I thought about limiting it to 100mm drop because 125mm just seemed too much but then I got used to only dropping it as much as I needed instead of slamming it all the way down. I put the 75mm GravityDropper on a spare bike. Took it for a ride a few weeks back, immediately smashed my nuts on the back of the saddle on the first steep descent. Once you get used to having the saddle right down low, it’s very hard to go back. Now I’m eyeing up 150mm posts.
molgripsFree MemberAs I think I’ve said before (see, I do remember some stuff 😉 ) in flat places like Ashton Court the default position is about 50mm down, and it only goes up for climbs.
molgripsFree MemberI do wonder if dropper ubiquity contributes towards the continued progression of 29ers and the demolition of the ’29ers handle slowly’ concept.
My Trek (the bike in question) steered quickly and well enough, but in twisty stuff it wasn’t as agile as I’d have liked. But that may have just been down to higher CoG compounded by larger wheels – which would slow handling down, as you’d expect. But being able to lower the CoG by a good 50-75mm seems to offset that. The steering was still quick but rapid turns and manoevring of the bike were far easier.
I now wish I’d been dilligent in selecting the correct bike when I upload to Strava, because I’d have been able to measure performance. Although I suspect I may have a PR on the fence line (flat-ish singletrack with many trees at Castell Coch) across all my bikes.
Kryton57Full MemberWell I’m off for my first dropper-ride today. A quick sit on the bike and suddenly I get the 2-3 cm lower on singletrack thing. As a racer I have my saddle as high as my road bikes for power/leg extension, so in the twisty stuff I’ve a feeling this’ll help COG and balance.
On the negative side the dropper is about to get covered in all kinds of mud, hmmm….
I’ll drop a note in later after the ride.
molgripsFree MemberWill look forward to the report. But also remember like all big changes it takes time to learn to get the best from it.
BruiseWilliesFree MemberI fitted a TMars one to a 96 Trek 850 recently and I have to say I’m sold. It just works so well, even for old XC geometry bikes.
I had to do a ton of work to it to get it function though; machine it down from 27.2 to 26.7mm. It’s a snug fit now, but about 95% of the post is inside the frame, so I cant see it being too much of an issue. I also had to turn the post round, re-drill the pin positions, make internal spacers and stops and also pressed in a plastic rod inside the sliding post. This has the effect of creating vacuum inside the post, using the bottom cap as a throttle, slowing down the somewhat aggressive return speed.
It now has 50mm of drop, but on an old, high standover frame, that’s about as much as you’re practically going to get. Enough to make a difference though.
hols2Free MemberI had to do a ton of work to it to get it function though; machine it down from 27.2 to 26.7mm.
I have a feeling that GravityDropper used to do a 26.8mm post, but not sure. From your picture, it looks like you might squeeze a 3″ drop GravityDropper in there with a lower stack saddle. I think the TMars is basically a cheaper knockoff of the GravityDropper, so functionality would probably be pretty much the same. I think the worst thing about the GravityDropper is the flimsy lever, not sure if TMars improved on that at all.
molgripsFree MemberThat’s a decent ride for a rainy day Kryton, or are you being lazy with your reporting?
Kryton57Full MemberHa Ha – here I am. a 2hr ride, lots of cleaning to do!
This. It took a fair while to get my brain into gear with it. At first, I went straight t the nearest big drop off – a 13ft rooty drop into a bomb hole. I spent some time going down it several times, dropper up then down and so on. I came away for the rest of the ride thinking “hmmm, yes there was more confidence there” but also feeling a little alien not have the feel of the saddle around my upper thigh.
As time went on I remember mol grips words, and started to let the saddle down a few cm on downhill single track – and it was here the real revelation occurred. As you said, suddenly I found myself more naturally in the attack position knowing I couldn’t lazily sit down on a Saddle too low. I was moving the bike around, much further back, my heels where down more naturally by default as I hovered and I was able to move the bike around much more with more body english – quite amazing the amount of difference and confidence it provided – all this in muddy slippy conditions which are not my favourite. I came away thinking I’ve deferred to some bad “sitting” habits as I move from Trail to race and started to remind myself of my prior Jedi training, and few I hd more time/focus to look through the trail as my body was much more “loose”
I’m now thinking about which races I’d use it in – pretty much anything where theres some fast single track to find some time, definitely the Hope Marathon, Hadliegh…
So, a thumbs up!
The topic ‘Dropper on XC bike – side-effects’ is closed to new replies.
