Do all black alu ri...
[Closed] Do all black alu rims have the black rub off the brake surface using rim brakes?
24 Users
Offline  yohandsome
Share this post
e
Is that a problem with all black alu rims using rim brakes? Are there some that don't have this (purely aesthetic) issue?
If not I guess carbon wheels or disc brakes are the two options..?
Posted : 04/12/2019 3:13 pm
Offline  simondbarnes
Share this post
DT Swiss ones with the oxic braking surface don't.
Posted : 04/12/2019 3:15 pm
Offline  submarined
Share this post
For anodised ones, Yes, because anodising is a surface treatment. The Mavic ones with the ceramic coating didn't used to wear particularly badly.
Offline  oikeith
Share this post
Yes
Posted : 04/12/2019 3:16 pm
Offline  isoo
Share this post
Or brakeless...
Posted : 04/12/2019 3:17 pm
Offline  yohandsome
Share this post
Seems like chinese carbon is the budget option here then, I hear there are some decent options around today.
Also found that this was discussed ad nauseum here: https://weightweenies.starbike.com/forum/viewtopic.php?t=131819
Posted : 04/12/2019 3:25 pm
Offline  trail_rat
Share this post
To be fair slightly scuffed rims would be low down on the pictured bikes list of aesthetic issues.
Posted : 04/12/2019 3:28 pm
Offline  yohandsome
Share this post
Seems like even the DT coating isn't that good "From my experiance I can confirm that OXIC coating from DT works great in dry conditions. In wet is very fragile, lasts very short and is not as good as advertised on DT website."
Posted : 04/12/2019 3:32 pm
Offline  chakaping
Share this post
Is that a problem
In what way do you regard it as a "problem"?
Most black alu rims have an un-anodised brake track anyway IME.
Posted : 04/12/2019 3:34 pm
Offline  mikey3
Share this post
What beard oil do you use?
Posted : 04/12/2019 3:41 pm
Offline  yohandsome
Share this post
Posted : 04/12/2019 3:43 pm
Offline  chakaping
Share this post
And why are you posting pics of track bikes (which don't have brakes)?
Posted : 04/12/2019 3:45 pm
Offline  yohandsome
Share this post
cause
Posted : 04/12/2019 3:49 pm
Offline  kerley
Share this post
Mavic Open Pro CD used to be okay (the ceramic coated ones as referred to above) but even those don't completely hold up once you have wet and gritty brake pads rubbing against them. They were also dark grey rather than black.
If you are using a rim brake then not much choice really other than carbon as you say.
Posted : 04/12/2019 3:51 pm
Offline  thisisnotaspoon
Share this post
If you want a fixie, get a fixie with brakes, not a track bike without them.
The reasons are thus:
1) Legality, and rule 1, riding brake less is a dick move.
2) 99% of people DGAS about what bike you're on, you are a cyclist and therefore sub human, other nuances are irrelevant to them. Of the other 1%, 99% of those think you're a hipster on a fixie and don't care about further nuances of your bike. Of the 1% of the 1% (other fixie riding hipsters) you'd probably get more kudos riding something that actually looked like it was ridden 365 days a year rather than looking like you got lost on the way to the velodrome wobbling around east London on an occasionally dry day.
Besides, track riders wouldn't be seen dead outside a velodrome. Tubs are a faff to fix after a puncture, riding outside gets punctures. And indoor velodromes won't let you ride bikes that look like they've been ridden outside.
And...... this time of year silver rims are hidden under a crust of brake dust anyway, what's the problem.
Bulldog if I want to smell nice, beard balm if i just want to make it shiny.
Posted : 04/12/2019 3:54 pm
Offline  yohandsome
Share this post
Personally looking to build a fast singlespeed (again), the frames I've shown are designed for both track and street use w brakes.
Black wheels look sweet on some frames, but wondering if it's worth a damn if the black just rubbs off, hence this thread.
Seems like carbon is the only surefire option, and then whether cheap or used carbon wheels are safe is another can of worms 😁
Posted : 04/12/2019 4:17 pm
Offline  damascus
Share this post
I hated the brake rub on black rims or the silver brake surface on a black rim.
Just upgrade to disc and don't worry about it again.
Offline  kerley
Share this post
Finding a track frame that has disc brake mounts is not going to happen, a track frame shouldn't even have holes for calliper brakes (mine doesn't)
Posted : 04/12/2019 4:27 pm
Share this post
Well, that and whether it's worth bothering with carbon rim brakes in the wet.
Why not just go with some nice deep silver rims? Less fashion-victimy. On the flip side, less fashionable so less choice.
I'd go disk brakes and deep carbon rims. I think it looks ace on a steel bike. If you want to impress hipsters, get those Pauls anniversary calipers.
Genesis day 1, surly cross check, Arkose SS, Charge Plug, All City Nature Boy, On-One Pompetamine. Or any road disk frame with a PF30 converter.
Posted : 04/12/2019 4:29 pm
Offline  yohandsome
Share this post
I wouldn't mind converting to disc on the front and running the rear fixed for the ultimate bastard hybrid, but I'd need a new fork and wheel, which also wouldn't really match the rest of the bike.
I'd rather just get a cheap pair of carbon wheels and sell the original ones, it's flat where I live so overheating isn't likely, also the reason why singlespeed is appealing (48x14T as I like to mash).
Thx for the suggestions notaspoon!
Posted : 04/12/2019 4:39 pm
Share this post
Not so much the overheating, just the lack of friction once wet.
Posted : 04/12/2019 4:41 pm
Offline  kerley
Share this post
Looks like you missed the track frame part of my "finding a track frame". Yes there are loads of single speed frames but no track frames.
Posted : 04/12/2019 4:44 pm
Offline  easily
Share this post
I wonder if anyone can spot the clue in the words 'track frame' that hints at why they are not very good for the road.
Posted : 04/12/2019 4:49 pm
Offline  oldnpastit
Share this post
My carbon rims are nice and black. No overheating. They've not had that much riding in the rain (why go out in the rain?) but what they _have_ had has been fine.
Posted : 04/12/2019 4:51 pm
Offline  trail_rat
Share this post
Who (bar hipsters) actually wants to ride a track frame on the road.
Utterly the entirely wrong tool for the job.
Posted : 04/12/2019 5:11 pm
Share this post
Looks like you missed the track frame part of my “finding a track frame”. Yes there are loads of single speed frames but no track frames.
Indeed, but the OP doesn't want a track bike
Posted : 04/12/2019 5:28 pm
Offline  bob_summers
Share this post
On Ambrosio Cronos etc it just rubbed off round the spokes which would really set off some folk these days
Posted : 04/12/2019 5:38 pm
Offline  yohandsome
Share this post
These are examples of hybrid track/road frames, designed for the track and road. The key feature is the horizontal dropouts. Geo is a bit more aggressive than pure SS frames (which I like), the trade-off is lack off disc brake or fender mount options.
Posted : 04/12/2019 5:43 pm
Share this post
Quite like the look of that Aventon TBH, I've got delusions of joining the local track league next year so that + an easily removed front brake and cross-top lever could be a good setup that avoids having to drive to the track (it's an outdoor track to tubs are less of a benefit). Something like a Langster would also be an option, but possibly too road biased.
Posted : 05/12/2019 11:28 am
Offline  kerley
Share this post
They are not really hybrid track/road frames, they are track frames that have drilling for brakes to expand the market. That is the only difference.
Me. I have ridden track frames on road and gravel for the last 20 years and ride around 4,000 miles per year on one. They ride pretty much like a road bike with a slightly higher BB yet are much cleaner looking (helped even more by riding brakeless) and I just prefer them.
Posted : 05/12/2019 11:47 am
Offline  honourablegeorge
Share this post
kerley
Most full suspension track frames have disc mounts. I run Lyriks on mine.
Posted : 05/12/2019 11:49 am
Offline  kerley
Share this post
Indeed, but the OP doesn’t want a track bike
Well maybe the OP shouldn't have posted two pictures of track bikes and then also stated they like the more aggressive geometry of a track frame...
Offline  philjunior
Share this post
Ceramic braking surfaces are the only option that doesn't rub off. (Mavic CD ceramic, the DT one both mentioned above, and Rigida even does it)
It can chip off if you hit potholes etc. though.
Posted : 05/12/2019 11:53 am
Share this post
Calm down Kerley, you've argued yourself into a circle.
a track frame shouldn’t even have holes for calliper (sp) brakes
Posted : 05/12/2019 11:58 am
Offline  trail_rat
Share this post
No they dont - unless your reference point is 20 years out of date.
Posted : 05/12/2019 12:00 pm
Offline  yohandsome
Share this post
The Aventon should look even better in person, but I suspect the tone of the paint varies between production batches, hopefully it looks closer to this:
Kerley: not sure if they have a pur(ist) track geo, seems like most of the Cordobas end up on the street?
Posted : 05/12/2019 12:09 pm
Offline  kerley
Share this post
Calm down Kerley, you’ve argued yourself into a circle.
Not at all. A track frame clearly doesn't need holes for brakes. If however you take a track frame and drill it for brakes then it is still a track frame - as the two examples pictured in this thread
Posted : 05/12/2019 12:23 pm
Share this post
Looking at the geo chart it's actually steeper/taller than some out and out track frames.
Semantics though, road bikes aren't a homogeneous set of geometry figures and neither are track frames. You could probably find some Crit specific frame with similar geometry if you shopped around.
Not at all. A track frame clearly doesn’t need holes for brakes. If however you take a track frame and drill it for brakes then it is still a track frame – as the two examples pictured in this thread
So we've ascertained that a whole gamut of fixed gear frames with anything from out and out track geometry through to disk braked SSCX bikes is available. Track/road hybrids if you will?
FWIW the difference between that Cinelli and my CAAD4 road bike is 8mm in the BB, the HA is the same. The Aventon is half a degree steeper. It's different, but not to the extent it's going to become unrideable.
Posted : 05/12/2019 12:27 pm
Offline  kerley
Share this post
No they dont – unless your reference point is 20 years out of date.
My reference point is 20 years out of date yes. I hadn't realised that the geometry of the road bike had changed in the last 20 years, enlighten me.
Anyhow, I like riding them on the road.
0.5 degree of head angle, 10mm less rake and 10mm less BB drop do not make a bike go from the perfect fast road bike to something "Utterly the entirely wrong tool for the job"
Posted : 05/12/2019 12:30 pm
Offline  kerley
Share this post
Semantics though, road bikes aren’t a homogeneous set of geometry figures and neither are track frames. You could probably find some Crit specific frame with similar geometry if you shopped around.
Agree, although the higher BB of the track frame is fairly consistent.
Posted : 05/12/2019 12:33 pm
Offline  TiRed
Share this post
Do you really want a 74 degree head angle track bike? My lightest road bike is a carbon Dolan Seta track bike with a Ritchey monocoque road fork and a front brake. Sure you can swap to carbon rims, but if you are running just a front brake, the I would not as breaking performance will be impacted. In fact my fastest HED race wheels are alloy rims because I like the braking.
Black Open Pro rims with shiny brake track, shiny spokes and hubs and you will have a fine-looking bike that weights little. If you want nice high front, get a Dolan Seta. You can drill out the front Alpina fork which is made for a front brake - I have that set up on my fixed TT bike (Dolan pre cursa).
And don't run it singlespeed. It hurts the baby robbins.
Posted : 05/12/2019 12:38 pm
Offline  epicyclo
Share this post
Black is passé.
Highly polished alloy rims with silver spokes look much better, especially with red. And there's no problem about the brake track colour then...
Posted : 05/12/2019 2:06 pm
Offline  joshvegas
Share this post
Couldn't look much worse!
Posted : 05/12/2019 2:23 pm
Offline  yohandsome
Share this post
@joshvegas do show us a beautiful track bike/singlespeed! you've got me all excited now
Posted : 05/12/2019 3:06 pm
Offline  yohandsome
Share this post
BTW speaking of CAADz
Posted : 05/12/2019 3:07 pm
Offline  epicyclo
Share this post
Fuji Feather
Posted : 05/12/2019 3:16 pm
Offline  cookeaa
Share this post
I wouldn’t mind converting to disc on the front and running the rear fixed for the ultimate bastard hybrid, but I’d need a new fork and wheel, which also wouldn’t really match the rest of the bike.
I actually did this for a while for use as a year-round commuter.
It was fine while the weather was nice, but if front wheel grip couldn't be guarunteed (i.e. in the wet or icy months) I was always a bit more concerned about my ability to stop. while you can stop a fixed bike using the drivetrain alone, it's never as effective as a brake if you've only got one conventionally braked wheel it's always a bit spicier in winter...
These days I still run the same bike fixed (brakeless) rear, with a front rim brake (flogged the disc fork), but it's got a pair of risers now, the guards have gone and is only really for fair weather use as a pub bike.
TBH it sounds like function is taking 2nd place to aesthetics here.
If you want to be on the absolute bleeding edge have a matching frame and fork and not scuff your rims could you consider fitting a drum brake on the front? None of the other Hipsterfixie****s will have one of those yet...
Posted : 05/12/2019 3:27 pm
Offline  plus-one
Share this post
AliExpress carbon on my Kona
[url= https://i.postimg.cc/NfxTfGHB/27591-A67-DA05-438-F-8-CBE-374-CA1-FF9199.jp g" target="_blank">https://i.postimg.cc/NfxTfGHB/27591-A67-DA05-438-F-8-CBE-374-CA1-FF9199.jp g"/> [/img][/url]
Posted : 05/12/2019 3:45 pm
Offline  yohandsome
Share this post
@cookeaa
I want to make riding more fun, and not just a slog from A to B in the most effective way possible. Aesthetics is part of it, so is light weight, certain handling characteristics, low maintenance needs, I also like to grind high gears partly due to building my legs doing so. Aesthetics is less than 50% of this.
Aventon Cordoba plus 38 mm chinesium carbon wheels seems to be the budget way to go here, sad they're so expensive in Europe compared to the US.
Posted : 05/12/2019 4:30 pm
Offline  joshvegas
Share this post
null
Like this you mean?
The aventon is grim.
The cinelli is not bad.
But skinny steel.... Phwoar
Add skinny wheels... Phwoarerer
Add an njs stamp or two... Fappity fappity fap.
Posted : 05/12/2019 5:55 pm
Offline  kerley
Share this post
That is exactly why I ride track frames on the road and gravel.
You could certainly do lightweight with carbon rims and the Dolan Seta frame that TiRed mentions. Could be sub 6kg. Lots of good track frames on eBay if you don't mind used. My current frame is a Langster Pro (1500g frame with 340g full carbon fork) which only cost £200 and was in mint condition. Weight with road tyres and no special light parts is 6.3kg
You should also go fixed, single speed just feels a chore compared to it.
Posted : 05/12/2019 6:09 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
