I have a lezene digital.
It reads the same pressures repeatedly, looks fancy, easy to get in a bag (good)
but
massively under reads the pressure and was expensive
. (Bad)
Well bad for setting up suspension with guides. My MRP has two air chambers balanced against each other. This was fine with my analog shock pump until it died. The digital one is waaaay under reading.
If you are going to set the sag at 25% and want the same psi every time you pump it up, then it would be mint.
It was much more expensive than an analog one and annoys me evey time I compare it’s reading to a recommendation.
