Home › Forums › Bike Forum › Dear Hope Technology,
- This topic has 141 replies, 84 voices, and was last updated 9 years ago by enfht.
thegreatapeFree Member
And looking at Kimbers profile…he’s in London, not Barnoldswick, so that was probably a spoof reply and I’m still waiting on an explanation.
50/50 I reckon.
sharkattackFull MemberAnd looking at Kimbers profile…he’s in London, not Barnoldswick, so that was probably a spoof reply
Lol at the futility of trying to drum up a bit of ill will against Hope in this crowd.
jamesftsFree MemberFlippin’ ek is it really that hard for people to pick up the phone these days… ffs.
globaltiFree MemberDismantling the wheel may be easy if you’re a wheel builder and you’ve got the time but then to send the whole hub when only the freehub needed attention is a bit odd. I’d have just done what I did last week – take off the freehub, clean it all up and regrease and get my friendly LBS mechanic to knock out the bearings and fit new, only because I’m too lazy to do it and the hammering gives me a headache. All sorted in 5 minutes for £8.00.
Yes, rear hub bearings and freehub bearings aren’t Hope’s strongest area but then Hope don’t make the bearings. I have a pair of original Ti-glide hubs and have replaced the rear bearings numerous times; my belief is that standard ball bearings don’t cope very well with lateral stresses and they certainly don’t like British weather and mud.
diggaFree MemberIf the OP thinks the Hope OEM bearings are crap, he’d best avoid the cheap fleaBay copies. 3 months I got on the front wheel of my (not very heavily used) DH bike.
fallsoffalotFree MemberTo be fair to hope their customer service is probably the best around, but it has to be as no one would buy their products because it does keep breaking.
chiefgrooveguruFull MemberTo be fair to hope their customer service is probably the best around, but it has to be as no one would buy their products because it does keep breaking.
My bikes must be freak examples – Hope parts are two headsets, two bottom brackets, four hubs, two sets of brakes, between 1 and 4.5 years old. Frequent riding in all weathers. Only thing that’s been changed is brake fluid, pads and one disk because I wore it so thin.
daveatextremistsdotcoukFull MemberThat reminds me – must moan to Chris King because their ring drive lube freezes below -4 and it just spins out.
mick_rFull MemberI’ve had the same thing happen – half a brain and a quick google or search on stw told me it is a common problem so just sent the freehub back (and got a full new one by return post).
All the issues with Pro 2 are down to “progress”. The innards of the old XC hub used to last a lot longer (my eldest kid is now running one that has just turned 19 years old) but(some)people wanted big diameter through axle hubs.
So the axle is bigger and everything else has to be packaged to suit. So the bearings are smaller, and leaf springs take up less space than the old coils. The only inexcusable bit is that it is now just a plastic face “seal” behind the freehub rather than a proper full radial contact seal – so the problem often begins with muck and moisture getting in. I don’t like having to do it, but pulling the freehub off every few months and checking for broken springs / cleaning and lubing inside stops future major failures.
sharkattackFull MemberMy bikes must be freak examples – Hope parts are two headsets, two bottom brackets, four hubs, two sets of brakes, between 1 and 4.5 years old. Frequent riding in all weathers. Only thing that’s been changed is brake fluid, pads and one disk because I wore it so thin.
Lots of Hope stuff does last forever. I’ve never had any problems myself.
But, I worked in a bike shop for a couple of years that was a major Hope dealer and I did see a lot of kit being sent back. Mostly rear hubs. It’s nice kit but it’s not invincible. Then again, they’re a pleasure to deal with.
reggiegasketFree MemberQR could be too tight, causing premature wear?
Maybe you give your drivetrain a hard time..
maybe you are a samurai with the jetwash.. who knows.
Not wanting to side with the OP but… Hope hubs are okay but they aren’t as bulletproof as people make out IME. I’ve had maybe ten sets of Pro2/Mono/Pro2 EVO now and maybe a third of them wore pretty quickly and needed their bearings replacing after less than a year. Not a big deal but there you go.
mick_rFull MemberQR could be too tight, causing premature wear?
The QR does not load the freehub bearings – just the axle down the middle. My failure was with a bolt in ss hub.
I’m 99% certain my failure was fractured leaf spring(s) plus general muck and moisture trashing the freehub bearing – the problem bit is usually a bare needle roller in the middle that relies entirely on the (lack of) external sealing.
With a bit of care they are a good hub (we have 4 sets in the houshold).
manton69Free MemberJust flipping this round a bit:
Hope receive a hub that is broken. Takes a few minutes to fix and send back. job done.
Time taken to enter in to conversation/write to tell customer that shit happens/ bearings rubbish/you did not service it/many other unknown reasons* (delete as appropriate) takes as much time as it did to fix the issue.
Customer receives feedback and starts to talk/reply/converse with Hope.
Time is money for a small British industry that actually makes things. If you fix the issue and have a good rep for that then your name holds good. If you start to waste time on a multitude of non profitable work then you start to have to cut margins in actually making stuff. Downwards spiral and ffffffut there goes another manufacturer. I think that they have got the balance right and you can still phone them to see if the guy doing the repairs even thought to investigate why it happened.
just a thought….
grenosteveFree MemberI can answer this!
Commercial bearings are type tested. This means they are made in very high numbers, and only a percentage are taken out and tested. in short, this keeps bearing costs down. They fail sometimes, and not all bad bearings can be caught at the manufacturing stage.
So basically, it happens, get over it.
And before you suggest they should use better bearings, no bearing company tests every single commercial bearing they manufacture, maybe the one offs they make for special projects, otherwise your hope hubs would cost a few hundred pounds more.
billyboyFree MemberMick r
Thanks for your tendered explanation. Your theory does make sense, I guess. Trouble is that if that is the true reason this free hub disintegrated in such a short time, it makes their product far less attractive to someone who wants a degree of long term durability between servicing, or bearing replacements.
vincienupFree MemberMaybe think yourself lucky?
A mate had a similar issue with a pro 2 Evo that came on the back of a brand new Alpine 160 and ended up paying LBS to replace bearings as neither vendor, Orange, nor Hope apparently wanted to look at warrantying it and claimed fair wear and tear. Again on a sub six month old bike…
Will balance that though that apart from a cracking freehub on a very old and sh pro 2 my experience of Hope hubs has been excellent.
PJ266Free MemberBearings are consumables, most manufacturers give 3 months warranty. Anything more is goodwill gesture.
SpeshpaulFull Member“Trouble is that if that is the true reason this free hub disintegrated in such a short time”
See, this is your problem, you are making a mountain out of a mole hill.
The free hub didn’t disintegrate, did it.
Two of the bearings in side failed.
Hope offered to warrenty it, you unlaced the wheel (?) and sent them the whole hub not just the free hub.
They replaced a load of stuff for free fedex’d back to you for free and you are still not happy.
You wonder why they haven’t replied to you?
Because they have figured out that nothing they say will make you happy.wwaswasFull MemberTrouble is that if that is the true reason this free hub disintegrated in such a short time, it makes their product far less attractive to someone who wants a degree of long term durability between servicing, or bearing replacements.
You’re relying on the law of averages making it so it’s not you twice.
At least you can service a Hope freehub – when Shimano ones fail it’s often cheaper to buy a whole hub than just the freehub.
MostlyBalancedFree MemberIn my experience it’s the freehub to hub body seals that are the weak link on Hope hubs. It also depends on what the soil is like where you ride. New Forest sand is very fine and seems to get past those seals particularly quickly. Rebuilds are an annual occurance for any bike used regularly through a New Forest winter.
Hope’s customer service is very good but they appear to prefer not to waste time getting into debates.daveatextremistsdotcouk – Member
That reminds me – must moan to Chris King because their ring drive lube freezes below -4 and it just spins out.Strip the hub and fill it with oil as recommended by CK for subzero use.
manton69Free MemberMostly Balanced : No need to replace the oil, you just need lots of incontinent friends able to pee on the hub to make it work again.
I offered to help only once on the ride that it happened on, but the rest of it was too funny. At the start all I had heard about was why I was riding my geared bike in the snow and not a far more suitable single speed with the superior CK hub. Now I had obviously forgotten that and never mentioned it again. Much….. 😀
MostlyBalancedFree MemberYes Manton, I learned the oil lesson the hard way. We’d all been in the pub a couple of hours for our Christmas curry whilst the temperature outside dropped. My CK wasn’t the only hub to freeze but being by far the most costly I got the most grief and the most offers of liquid help from beered up mates.
neilsonwheelsFree MemberMy pro2 pawl springs disintegrated after 7 years of abuse, I was outraged.!
globaltiFree MemberI’ve said this before but if you ever visit the Hope factory and see the mind-boggling amount of stuff lying around in trays waiting to be assembled you’ll understand why it’s really no skin off their noses to nip down and grab a couple of spare seals or bearings or whatever. They are big enough not to need to worry and still small enough to be able to do the small un-productive jobs.
RingoFree MemberMy freehub has cracked after 2 years use I told them laSt week they said they’d replace it. Can’t argue with that really
endurokidFree MemberOP, I’ve had this problem as you know (I posted my link on your previous thread), and I’m yet to return my freehub to Hope, but it will be going soon. I hope (no pun intended) that they warranty as quick as they did yours, although to get out riding I have bought and fitted a new one, but having a spare would be good!
One thing I’ve learnt is to service more often. You tend to forget about the freehub until its too late, but having bought the right tools to seal it properly I shall be removing them from both my bikes every few months to clean and lightly lube up, hopefuly by doing this I will get many years use out of them, but should they fail and it’s a genuine warranty issue, as opposed to poor maintenance I’m sure Hope will look after me.
Also, I get to keep an eye on the main hub bearings too, and spot any problems before they get beyond a minor service.
andyrmFree MemberI used to have to deal with customers, and one thing that is super annoying is this perception they have a right to an “explanation” for everything. No, you might have a right (although touch and go) to a replacement wear part like a bearing or whatever, but they don’t have to explain themselves to you. It’s not school.
Bearing in hub failed, hub fixed free of charge. End of story. No explanation or further discussion needed. And definitely not yet another internet moan on the site. Jesus wept, STW seems full of this shit these days.
If you need to vent your feelings in writing, use a notebook.
billyboyFree MemberMy problem is that I don’t want a hub that fails in less than 5 months. It’s no use to me, so I want to know why it failed then we all know where we are. If they don’t want to tell me then I can’t force them, but I’d suggest that that behaviour stretches the goodwill between them and an already disappointed customer. It’s not an isolated early failure, there are other folk on here who have experienced the same thing.
You are all consumers of these products.
Are you saying you are happy buying stuff that is not fit for purpose and breaks early?
whitestoneFree MemberI’ve Hope hubs on two of my bikes, on the road bike I’ve done around 20,000Km, in 2 years no servicing and it’s are fine. On my hardtail I’ve done 1600Km in 9 months. Again no servicing and it’s fine.
The above is anecdotal evidence as is yours and both are essentially meaningless. Without knowing the number of freewheel hubs sold and the number of returns it’s not possible to know if the unit is fit for purpose or not. Even the best production facility will have a percentage of returns. Products have a MTBF (Mean Time Before Failure), it doesn’t mean that *every* single unit of that product will last that long and some will last a lot longer. If there were any systematic problem with the units then Hope would be issuing a recall.
With MTB products there’s also the difference a rider can make – we all know people who are for whatever reason hard on their gear while others hardly ever seem to break anything.
NobeerinthefridgeFree MemberMakes mental note never to sell anything to billyboy, unless I suddenly possess the actual moon on a stick, and then decide to sell it.
esselgruntfuttockFree MemberIt’s no use to me, so I want to know why it failed then we all know where we are. If they don’t want to tell me then I can’t force them
I know why it failed. It failed because as a lot of people have said ‘shit happens’ What do you want from Hope apart from an explanation? You’ve had spot on service FFS!
Your’e getting on my wick now you are.RorschachFree MemberHe IS a special boy is’nt he?(I got told off for calling someone a dick earlier but seeing as he’s already been called a fanny I reckon I’d be ok….).
Although if I hearMy problem is that I don’t want a hub that fails in less than 5 months
one more bloomin time so help me….
(Top Tip…you have far more pressing problems than that my (billy)boy)swanny853Full MemberI think you said in your other thread that you found the problem after a month of creaking noises. That might explain why the axle was knackered and the bearings shredded rather than a bit notchy.
For what it’s worth, some things do just fail early. It’s why reviews sometimes include a ‘we had a problem but there are no obvious reasons for it and no one else has had one’ comments. Anecdotal evidence here suggests hope freehub bearings going (at least to that degree) is not a widespread problem. Hope have fixed your problem, so only if it happens again would I suggest you remount your high horse and go demanding answers.
ultimateweevilFree MemberI’m on my second set of wheels with Hope Pro 2 hubs, the first set last 5 years without a problem at all and I also have a set of 8 year old M4 brakes on my bike that have performed faultlessly over that time.
Hope make good stuff that lasts IME, if for some reason something doesn’t then their warranty service is second to none, what’s your issue with having used the service?
Big deal something failed it happens get over it they basically gave you a new hub for nothing.
deludedFree MemberI’ve had my Hope Pro 2 hubs since 2007. The bearings have been replaced both front & rear once. The abuse they’ve endured includes full submersion in Mendip Hills mud on many occasions, jet washes and a shockingly neglectful lack of care or maintenance by myself. I have to say as a ‘fit and forget’ component that does its job well they’ve been legendary – I was under the impression Hope service and warranties were up there as well.
unovoloFree Memberstuff that is not fit for purpose and breaks early
Define early? it is inevitable that sometimes things will go wrong and stuff will fail/break, it is after made by people and as such is open to human error ‘no one/thing is perfect’.
I think the general consensus is that Hope have sorted you out even when the failed item is classed as a consumable and you appear to be trying to create ill feeling.
Suck it up buttercup.dobiejessmoFree MemberThey would not tell you even if they knew its the way of the world.Going back bit brought a new 1987 Honda CR125 motorcrosser seized while I was running it in.Only had 30mins use.It turns out the tooling for the barrels were out so they were made oval.World wide problem Honda never admitted it but got a new barrel under warranty but took some hassle.Yet this was a very common problem that year.I was luckier than some they had gearbox problems as well.Only time this problem was mentioned was in a mx magazine two years later.The 1988 bike was brill.
The topic ‘Dear Hope Technology,’ is closed to new replies.
