I’ve contacted CRC about a warranty issue with my KS Supernatural dropper post
The post is 10 months old and has developed a fault (warranty period is 2 years)
Here is the detail I sent them in the warranty form: –
“The dropper post displays the following issues: –
1. When you sit on the saddle it drops without pressing the remote lever
2. When you then get up off the saddle it returns to full height without pressing the remote
I have disconnected the cable from the actuator to rule this out as being the problem
I’d prefer a repair/replacement of the original post as first choice”
CRC’s response has been: –
“Thanks for getting in contact and I’m sorry to hear you are having issues with your KS seatpost.
Your seatpost is coming up to a year old now and I wanted to check you have performed a full service to rule out a servicing issue. KS provide a great how to video on how to do this. http://www.kssuspension.com/support/
If after servicing the issue is still there then return the post to us for a warranty inspection.
I’d also reconmend to check the condition of the cables as they may be the cause of the issue and may need replaced.”
My expectation is that as the post is clearly faulty it’s a warranty issue which they should resolve.
I don’t feel that I should be asked to service the post myself in order to attempt to fix the issue.
Are my expectations reasonable?
