Home Forums Bike Forum Converting Sun Ringle Inferno Rims to Tubeless
Viewing 6 posts - 1 through 6 (of 6 total)
  • Converting Sun Ringle Inferno Rims to Tubeless
  • jwildcard
    Has anyone experience of converting the sun ringle inferno 25 rims to Tubeless. They are a 27.5 version with internal rim width of 20.3. I was hoping to convert them but have read a couple of older articles mentioning potential issues with certain types of tyres blowing off?
    walleater
    These are not tubeless compatible unless you happen to have a version that I have not seen. There is no ‘shelf’ on the rim for the tire bead to slide on to and be held in place.
    From memory, we managed to set up a few tubeless in the shop but it was a huge pain in the butt and I’ve no idea why we even tried….
    Maybe there are tubeless conversion kits / strips out there still that will work.
    johnnystorm
    I had the Inferno 23s on my Fargo. Sealed them up with regular stan’s type tape and ran then tubeless with the stock wire bead race kings, vittoria peyotes, on-one/vee gravel racers, challenge gravel somethings. Less faff than some supposed TL tyre/rim combos I’ve tried.
    tthew
    Joe’s conversion kits still appear to be a thing. Been using these on my singlespeed for years with no problem
    jwildcard
    Thanks for your thoughts on this so far. I had heard that you could convert many non tubeless rims to run tubeless with taping and adding the valves however the rims not being hooked will make it a trickier process right? With less chance of success even or maybe more difficultly on achieving a good seal. I haven’t used any tubeless before and was considering it for my road bike also which does have Tubeless Ready rims but there is less gain to be had I think when running 25-28mm tyres?
    zerocool
    The best way to convert something like that is Ghetto Tubeless GHETTO TUBELESS It’s Jared Graves approved and bombproof. All my bikes have been running it for years.
