How do I go about turning a wheel with a 7 speed shimano freewheel into a single speed?
I've seen the kits to turn cassette hubs into SS with spacers and a cog but not freewheels.
What's the best way to do it?
Also what tool do I need to remove this freewheel:
[img]
Conor
tool is a casetter removal tool and a chain whip (get an oil filter one from Halford as cheaper
Dont really get what you are asking when you take the caseette off you wil eithe rhave a free wheel or a screw thread
Free wheel = one of those kits
screw = a screw on single speed kit (I think you can get these but not sure where and may be wrong
This is a freewheel but so I need a freewheel specific tool not a cassette tool...
You can get screw on freewheels but they are the bmx type and so would position the cog right against the hub whereas I need it further out for a good chainline.
I was hoping there would be like a normal 7 speed freewheel but with only one cog positioned roughly in the middle
NO that is a cassette the free wheel is underneath it OR the casette screws on to the hub itself and the casette free wheels
[img]
I cant tell from the picture it could be eaither
IT looks like threads as cassette has a lock ring that laps over on to the last cog
Freewheels have the cassette integral to the freewheel.
Cassettes slide onto a splined freehub which is part of the whole hub.
This is the former [b]a freewheel[/b]
It is late I will get my coat though
sheldon says
A single BMX freewheel will thread right on. Unfortunately, the chain line is likely to only work with your granny gear unless you re-space the rear axle and re-dish the wheel.
Yeah I read that bit 🙁
Perhaps now is the time to finally attempt the one bike mechanic skill that has alluded me...
Rebuilding a wheel around a cassette hub!
Why? If you have a free wheel you have the best solution. All those cassette conversions are nowt but bodges. Stick a free wheel on. Scrounge a used one first if you are feeling really tight. Try the middle chain ring position. If all else fails fiddle with the wheel spacers and as a last resort redish it slowly. Sheldon is good but he didn't know every modern mountain bike by far.
Yes I recognise that - it's a freewheel as you say. The spined tool to remove it is about a fiver (I have one you could use if you can visit me in Nottingham!). Or take it to your local shop - it's a 10 second job to remove it with the right tool! The whole lot comes off leaving your bare hub which is threaded. Then you should be able to just screw on a singlespeed freewheel - White Industries (£70ish), Shimano (£20ish), Dicta (£8ish). Chainline might be a bit of an issue but you can play with that at the chainrings.
And I don't think you can "convert" that 7-speed - if you try dismantling it you'll see a step in the body of the underlying freewheel - some of the cogs are splined (not like a 9-speed cassette) and some screw on... Not worth the effort, buy a freewheel!
