Home Forums Bike Forum Conti Race 28 700c wide 60mm – where to buy ?
Viewing 11 posts - 1 through 11 (of 11 total)
  • Conti Race 28 700c wide 60mm – where to buy ?
  • FunkyDunc
    Punctured last night, used my last tube which is a Cont race 700c wide , which I think is 25-32mm
    These ones
    i can’t find them anywhere now!?
    What’s a good alternative?
    Ta
    FunkyDunc
    Bump 🙂
    aberdeenlune
    Halfords have them in stock you can order online.
    FunkyDunc
    Nope I checked – no store or home delivery stock 🙁
    cp
    Continental R28 Training Presta Long Valve Inner Tube – Black, 700C x 25-32 C/60 mm https://amzn.eu/d/2EMiF9S
    Spendy though
    I tend to use decathlon tubes on non tubeless applications
    https://www.decathlon.co.uk/p/700×23-32-bike-inner-tube-60mm-valve-presta/_/R-p-306878
    aberdeenlune
    The Cycle Clinic appear to have them available to order online. Price is fair as well.
    FunkyDunc
    If anyone is remotely interested, I got some on Amazon from Wolf Cycles – 5 for £28 which works out very cheap!
    trail_rat
    If you genuinely need 60mm valve. I highly recommend putting some cheap valve extensions in your saddlebag.
    Then you can use any tube you can scavenge.
    FunkyDunc
    Never thought about doing that , and such a simple solution !
    mrbadger
    Depends if the core is removable! Not all extenders fit all tubes, you need the right combo
    trail_rat
    Worth checking sure but I’ve neither seen extenders that NEED the core removed nor valves without removable cores for about 20 years.
