A colleague rides a Viking Belgravia as a commuter bike (stock pic below) and the chain protector is rattling really badly.
I’ve had a look at it and the chain protector is secured by a screw type fitting at the back which is held to the seat stay and then a bracket at the front that sits on the axle in between the bottom bracket and the cranks and then secures top and bottom to the chain protector.
It is the front that is loose as there is couple of mm play at the bottom bracket which is multiplied at either end and allows the bracket to rattle against the rotating chainset.
There doesn’t appear to be any way to tighten it up as the cranks are secure on the BB.
I appreciate this is easier to see rather than describe but any thoughts or suggestions?
EDIT: Here we go, it’s this type of bracket at the front (that’s not the actual model but is a clearer way of describing it). Obvs the BB goes through the centre and the chainguard is secured top and bottom
You’ve got to remove the cranks and tighten the BB shell to hold the bracket tight. This might need old school BB spanners (it usually does) and involve some cussing if you’ve not done it before. You’ll probably need to remove both crank arms and adjust the BB from the non drive side to remove the play. My guess is that’s it’s a cup and cone BB not a modern cartridge unit.
Have fun. 🙂
