Home Forums Chat Forum COM port problem
Viewing 40 posts - 1 through 40 (of 46 total)
  • COM port problem
  • racing_ralph
    I am trying to get my garmin connected to my laptop via a serial to USB connection. Keep getting the message "Failed to terminate RS232 thread" which i understand to be because other programs are trying to access the com port. How do i find out what it is and stop it?
    ojom
    dunno. try me on mid 14th norwegian iron forging techniques instead.
    racing_ralph
    lol, what do ya know?
    ojom
    its easier to list what i dont know.
    druidh
    Charcoal or wood?
    ojom
    seriously though… you got the baud rates n stuff all set up right?
    ojom
    and is it through a usb hub?
    Junkyard
    i had to use accesories>communications>hyper terminal to get mine to work but forget exactly what I had to do.
    Possibly not much help there but I no eff all about iron forging techniques from any tiome period/country
    Hip
    Pig skin bellows?
    ojom
    you need to give pin 2 a good talking too and tell it that if it doesnt get along with pin 5 better by tomorrow you are going to hurt it.
    Hip
    Tried assigning a different com port?
    druidh
    If you've installed the adaptor and driver, then it should have created a new COM port – i.e. one that can't possibly be in use by another app. Are you finding the right COM P{ort in Memory Map or whatever it is you're trying to connect with?
    Have you checked that your using NMEA protocol on the Garmin
    ojom
    are you a total noob Rob?
    racing_ralph
    its connected via the garmin serial cable to a usb/serial cable adaptor. Driver is installed as far as Windows tells me. all settings are done, tried changing it to com port 1 to no avail
    druidh
    It's unlikely to be COM port 1 though as that will already have been installed on your computer?
    numlock
    What type of USB converter? I would doubt you have other software trying to use a COM port. Some software is quite fussy about how a COM port is configured. I use old drivers for my USB converter as the newer ones only work with some software.
    ojom
    OMG Rob. stick to Key Stage 3 maths.
    racing_ralph
    all done and checked druidh. Its doing my fookin head in!
    racing_ralph
    FTDI adaptor
    druidh
    What COM Ports are listed in Device Manager?
    racing_ralph
    just the one that is connected to the gps (com port 20)
    Pieface
    I'd ask someone who knows about IT
    Unfortunately I can't think of anyone.
    racing_ralph
    thats 2 of us then
    Junkyard
    look on the bright side my Memory map wont even open and even Memory map dont know why I get an error every time I try. You are at least nearer to a solution than me and what better way to spend the last days of your LLLLLLLOOOOOOOOOONNNNNNNNGGGGGGG holiday
    druidh
    20???
    Some (particularly older) applications can't see past 4 or 8.
    racing_ralph
    thats just a random free one i used
    Hip
    Com port 1 is reserved for devices connected to the first physical com port. Try changing it to something sensible like 4
    Pieface
    Things like this just make me think bog standard bike computers are the way forward. Batteries last forever, they cost chips and tell you all you need to know.
    racing_ralph
    com port sorted on number 4 – error now is timing out sending packet;254!
    Hip
    Is your garmin configured to use NMEA?
    Pieface
    IKEA?
    racing_ralph
    garmin is set to "garmin" as in instructions
    racing_ralph
    if set to "nmea" then no GPS signal is received in MM
    Pieface
    Have you closed all other programs, especially ineternet connections?
    racing_ralph
    HTF would i be replying to this thread?
    Hip
    Is your MM gps set-up for usb or serial?
    racing_ralph
    serial
    Pieface
    Dime bar?
    geoffj
    It should be seeing it as a USB device not serial.
    Pieface
    Oats, that'll sort you out, otherwise Wheat is a good un. Failing that Taggart should do the trick.
The topic ‘COM port problem’ is closed to new replies.
