Home Forums Chat Forum Tamiya and other R/C vehicles (not just for Christmas)
Viewing 40 posts - 641 through 680 (of 2,571 total)
  • Tamiya and other R/C vehicles (not just for Christmas)
  • flange
    @demonracer – that’s awesome! Really nice welds too. Interesting what you say about prep and not bothering to mitre if I’m using the mig, if the come out like that I’ll not bother!
    I just sourced 4mm solid rod off eBay, it’s not too expensive. On the model above is that going on a standard chassis or are you building that too?
    clubby
    Wow, that’s impressive.
    Racing fighter build coming along nicely, doing a section every few nights. Last night was gear box and rear subframe. Really enjoying it so far.
    Only one mistake so far when I fitted a rear wishbone to the front. At least it was a quick fix.
    Can’t put off cutting the body out much longer. Might get a chance today if the boy gives me half an hours peace.
    Thanks to whoever recommended JIS screwdrivers. Got a cheap set off Amazon and definitely makes the build easier.
    demonracer
    @flange Thanks, Tacking it together without a close joint really did give a smoother weld for me, some mitres might still be needed it tube joints an extreme angle. Here’s a picture of another cage I built using the same technique.
    The cage above bolts up to an axial Axial chassis and the Toyota fj I showed before had a cut down Scx10ii chassis built in, it has running gear from the same chassis with the gearbox rotated 90 degrees to give more room For a possible interior.
    The last picture is of a cage I brazed together for a friend, the joints are slightly neater but it was more time consuming to build.
    @clubby
    the JIS driver is a great help building tamiya. Are you going to cut the body with scissors or score with a knife and snap?
    flange
    That. Is. Awesome! Well done sir, that’s fantastic work! Can I ask how you bend the tubing? Pipe bender or big hammer?
    My rear axle turned up today so I’m back in the conservatory tonight to figure out how to fit it. In other news my youngest step daughter destroyed my carisma Range Rover gearbox today so I need to have that in bits!
    stumpy01
    clubby
    That might have been me. I really struggled until I found a suitable screwdriver!
    Mine is the Neo Fighter, but I think I prefer the body & wheels of the Racing Fighter – it’s the same chassis though.
    When you get to the shocks, take your time & try to have something to hold them vertically, even if you make a folded card stand or something. I have seem some forums where they polish the shafts before assembling.
    Also you literally get just enough shock oil. I think I ended up filling the first shock spot-on, then very slightly over-filled the second shock. This meant that the third & fourth were a bit underfilled. Just take your time – I was keen to get on, so probably rushed it a bit.
    clubby
    @demonracer I went with a combination of both. Body was a lot of curves and cut outs. Rough cut with kitchen scissors to trim waste, then curved craft scissors for the body cut out. Used a knife for the right angle cut on the back of the cab. Found the long cuts on the body too tricky to knife trim due to flex and the difficulty of supporting the inside. Curved scissors were great but still a very stressful 45 minutes.
    flange
    Carpetkana didn’t work out so well on the deep shag pile at my mums
    Drift rc
    weeksy
    Merak, check your PM pleas 🙂
    ThePerfectKiss
    @weeksy IIRC if your going to replace a 380 with a 540 motor you’ll need an 18T pinion, maybe worth a google to confirm, i seem to remember doing it on my black grasshopper…
    Tamiya garage!
    weeksy
    The baby FTX Colt has arrived and is charging
    2020-04-24_11-42-23 by Steve Weeks[/url], on Flickr
    2020-04-24_11-42-18 by Steve Weeks[/url], on Flickr
    2020-04-24_11-42-12 by Steve Weeks[/url], on Flickr
    2020-04-24_11-42-06 by Steve Weeks[/url], on Flickr
    weeksy
    jam-bo
    i bet your neighbours love you…
    Harry_the_Spider
    Grasshopper looks better.
    flicker
    Yeah, kids playing in the street, should be in school…..oh…
    mutter…. grumble….
    racefaceec90
    hugo
    Just seen this FTX copy in Aliexpress….
    Could be tempted for 72 quid posted. Looks like many parts are transferable as well.
    doomanic
    Having been dipping in and out of this thread for a while now, I’d just like to say I hate you all…
    With that in mind I dug this out of the garage today;
    It’s an Associated RC8 with an RC Products electric conversion that I took in PX for a JConcepts BJ4 when I owned a model shop that was the distributor.
    Tiger6791
    ooooohhh
    I gave my RC10 away 🙁
    demonracer
    @flange I normally bend the rod with a combo of a hammer, big vice and some kind of form, either a socket or a nice big bolt is good.
    Which axle did you go for? Are you building it as rear wheel drive?
    doomanic
    @Tiger6791 I’ve had a few RC10s including a World’s car, a B3 and a B4. Last cars were a Losi XX4 with many, many bespoke parts and the B4, I haven’t raced since 2007 though.
    Tiger6791
    Never got to a Lossi
    Used to race Airevalley buggy club.
    Started with a Hornet and ended spending a small fortune in Otley modelsport
    Think I went
    Tam Hornet
    Tam Avante
    Sch Cat & Cougar
    RC10
    Then girls & pub…
    Harry_the_Spider
    @weeksy What sort of run time are you getting off the batteries on your Grashopper now that you’ve fitted bearings?
    weeksy
    It’s over an hour mate, but not measured it sorry, I’d think 90 minutes
    clubby
    stumpy01
    Great advice, thanks. Took a cardboard box and made four holes in the top to keep the shocks upright. Kit must have changed though as I’ve about half the bottle of oil left! At least I hope it’s changed. Shocks are amazing wee bits of kit. Enjoyed building them almost as much as the gearbox.
    Body currently drying waiting on third coat of paint. Main body looks good, but unsure about wing. Think I went a bit heavy on first coat. Also difficult to get into side plates. We’ll see later on.
    unclezaskar
    here’s my RC bruiser – its an Axial yeti rock racer
    I used to race 1/10th electric indoors RC and also electric buggys but just wanted something to have a bit of fun with….this thing is mental, currently running 3S Li-po pack and some crazy fast brushless motor.(can accommodate up to 6S !)
    only getting 25 minute run times, but the upside is that it will wheelie off the throttle and flat out must be doing around 30mph which considering its size ain’t bad (its marketed as 10th scale but its mahoosive..)
    great fun as a kit to build as its quite a complex set-up suspension wise with double wishbone up front but live axle on 4-link trailing arms out back. Handling is a little ‘interesting’ to say the least with some major grip-roll issues out of the box (only cured by fitting some denser foams inside wheels..
    flange
    @demonracer – at the moment I’m just using a spare from an old FTX canyon for mock up. I’d like a yeti score but they seems crazy money, so maybe something off eBay. It’ll be 2wd, hopefully with a 3s. I’ve got a bit of a mix of components that I’ve pilfered from other cars so who knows whether it’ll work!
    Going to start bending and cutting pipe this evening. Then maybe some welding tomorrow fingers crossed!
    MrPottatoHead
    Life at a different pace. Been having fun building obstacles. Son is def getting the hang of driving!
    Harry_the_Spider
    Grasshopper bundle with bigger battery, fast charger and bearings bought! BOOM!
    Fessed up to the wife about the cost in advance and had the “You’re not going to lose your job are you?” chat.
    Feel equally guilty and giddy. I’ve wanted one of these since I saw one in Beatties off Market Street in Manchester when I was a kid.
    I am 51.
    stumpy01
    Hmmm, was considering one of FTX colts for my daughter but looks way too quick for a 4 yr old!
    Quite fancy one myself though!
    Harry_the_Spider
    @Rusty
    When this shit show is over shall we arrange a play date for the North West chapter? Might get messy with us all on the same frequency though.
    grahamt1980
    The colt is a bit much for little ones, our near 5 year old loves it but can’t do throttle control at all so just does steering.
    He still loves it though. Currently modding some 1600mah batteries to fit
    RustySpanner
    Yeah boy!
    Drop us your new address and I’ll send you a 540 motor. 🙂
    Harry_the_Spider
    Cheers fella.
    I am genuinely excited about getting this. I blame you.
    This image from the mid 80s was burned into my mind.
    diz
    @Rusty Spanner and Harry the Spider i’m up for a north west bash
    RustySpanner
    Sounds like a plan to me!
    Binners next.
    I’m sure we could find him something that doesn’t turn too far to the left. 🙂
    Harry_the_Spider
    Right then. As soon as the plague has gone we’ll have a big kids’ day out.
    clubby
    It lives!
    Please be kind, it’s my first attempt at paint and stickers so definitely not up to @Merak standards, but overall I’m quite pleased.
    Wiring needs tidied up too, but I’m going to run it a few times then address that just in case it need to come apart after shakedown.
    Some assembly required by Steven Clubb[/url], on Flickr
    Chassis by Steven Clubb[/url], on Flickr
    Paint and body by Steven Clubb[/url], on Flickr
    Finished by Steven Clubb[/url], on Flickr
    Harry_the_Spider
    Looking good. Weeksy will no doubt have one order by lunchtime on the back of those photos.
    weeksy
    LOL i have 2, that’s plenty of RC cars, bigger things to buy at the moment.
    Harry_the_Spider
    Had an email this morning saying that my order has been processed.
    #IsExcite
