Central heating wants to be on all the time.
The hot water circuit responds to the timer, will only feed the coil in the tank when it’s told to.
But unless the boiler’s switched off, the central heating will be on, whether the panel is saying it should be on or off.
I’ve tried talking the control panel off the backplate, and the same happens: hot water off, CH on.
The thermostat relay clicks when I turn it back and forth over the current temp, so that seems to be working fine too.
So where’s the problem? What’s telling the boiler to fire and feed the circuit when everything should be off?
Cheers for any help, and please don’t assume I know very much, or even anything about boilers and central heating!
