So, christened the link yesterday.
Set it up with 20 extra psi to get 30% sag (240psi vs 220psi – I’m about 88kg)
Also dialled in the original JTech compression/rebound settings and removed the 8000mm3 spacer.
I’ll be honest on the first trail I was a little underwhelmed. The bike felt a little loose and seemed to be limited on traction. The bike also didn’t seem to pop anymore and felt a bit lethargic.
I decided to completely open the LSC and only run a couple of clicks of rebound……
This was now a completely different bike – grip for days, the pop was back and i felt more in control.
Used pretty much all of the available travel (bout 5mm left by looking at the O-ring)
Was riding a mix of steep rooty/rocky trails and man made trail centre stuff (Ticknock, Dublin)
Need to hit some big jumps/drops before
I think about adding a spacer back in.
Definitely recommend the link to anyone thinking about it. Only issue now is the rear suspension is outclassing the front!
A service for the 36s should help that!
