Home Forums Chat Forum BSP pipe fittings. Very confused!
  • This topic has 11 replies, 8 voices, and was last updated 2 weeks ago by pk13.
Viewing 12 posts - 1 through 12 (of 12 total)
  • BSP pipe fittings. Very confused!
  • scruff9252
    I am working on a diy project. It calls for a specific pump (SU fuel pump fwiw) with what’s sold as 1/4”Bsp female threads.
    IMG_1320
    Bought the pump and a 1/4”bsp male thread to 6mm ID hosetail. IMG_1319
    clearly the two items, whilst sold as 1/4bsp are different sizes.
    no problem, pop off to local toolstation who have a 1/2”to1/4” bsp converter. 1/2” way to large but confusingly the 1/4” is the same as the pump diameter.
    Ok so the hose spigot I was originally sold was sent was wrong. As a check I asked if they had a 1/4bsp fitting I can check, and that was the size of the original spigot I brought in.
    so I have two items claiming to have 1/4bsp female threads being the same size and similarly two items with 1/4bsp male threads being the same size, but smaller diameter than the matching female threads.
    confused? I certainly am! what on earth is going on?
    what do I need to buy to fit my pump?
    Bear
    Could be 3/8”
    scruffythefirst
    3\8ths? About 15mm ID
    snaps
    The brass hosetail looks like 1/4 BSPP (parralel) is the pump 1/4 BSP tapered?
    Bear
    Might be a NPT thread or some obscure American thread too!
    lerk
    The hose tail(s) are 1/8”bsp
    1/4”bsp has a major diameter of 13mm ish like your pump.
    https://images.app.goo.gl/NwoWecc3uCChTEjm6
    whoever you’re buying your fittings from is thick!
    1
    thisisnotaspoon
    +1
    BSP fittings are sized based on the ID pipe they were attached to.  So modern 15mm (OD) copper pipe has 1/2″  fittings, whereas 8mm has 1/4″ fittings.
    1
    pk13
    Those fittings are the only thing I often have a spare bag of *ie I brought the wrong size/fit when I did the fuel system on my bus it was a lottery of non fitting fittings. I got so fed up at one point the lathe got fired up in my mates shed
    thisisnotaspoon
    I’m guessing that’s something more interesting than the STW standard issue T6 California @PK13?
    pk13
    Well it’s a vw. It did have full on fuel injecton but I’ve gone back to carbs less stress less fittings.
    Sometimes simple is best.
    Sui
    pk13
    You not thought about about getting SU injector conversions / throttle bodies?  Jenvey do some nice ones as do https://www.classicfuelinjection.co.uk/vw-beetle-single-36mm-kit – i tried some out in smoe older jags – they make a huge difference and way more efficient.
    If you already had injection you must still have the looms in place?
    pk13
    @sui everything is back in a big box in my garage thankfully vw engine wiring is all at one end so it was just unplugging the pin plug. When I get time I will revisit it definitely unless electric becomes viable in a full camper.
    I took the engine out to finish some panel work and just laziness made me put the carbs ect on I can be stubborn for all the wrong reasons lol.
