Bottom bracket repl...
[Closed] Bottom bracket replacement!
4 Users
The BB on my Vulcan has died.
it says on it
BC-73C
68+1.5
BC 1.37x24T
115M
L R
What does all this mean?!
The L came out the crank side which surely is the right side of the bike?
Is this a direct replacement? Is it worth spending any more.
http://www.ebay.co.uk/itm/Shimano-Sealed-Catridge-Bike-cycle-Bottom-Bracket-Square-Taper-New-VARIOUS-SIZES-/231090110019?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item35ce0b3e43
BTW I weighed the old one and it came in at 285grams... is this heavy?
Posted : 05/01/2015 7:55 pm
68 or 73 would be the width of the bottom bracket shell. As it states both I'd measure it just to be sure. 115 is the length of the spindle.
If I were replacing a square taper bb I'd go for one of these over the UN26 on ebay, even if it is a penny under the crc free delivery threshold...
http://www.chainreactioncycles.com/shimano-un55-square-taper-bottom-bracket/rp-prod71369
Posted : 05/01/2015 8:10 pm
so if I went for a 118 the crank would sit out another 1.5mm?
Thanks for your help
The crank sits a little too close to the frame which prevents the mech front changing efficiently (I've adjusted it to death and tried multiple ones).
http://www.halfords.com/cycling/cycling-parts/bottom-brackets/vp-bc73-68-x-118-square-taper-cartridge-bottom-bracket
Posted : 05/01/2015 8:31 pm
yeah that should be fine but it will affect your chain line slightly and your gears will need to be re-adjusted including the limiter screws on the front mech
I'd stick with Shimano BBs, the square taper ones last for eons. 🙂
Posted : 05/01/2015 8:41 pm
possibly worth ordering some 8mm allen crank bolts to go with a new bb. They don't always come with them and often they're the hex bolt type.
Posted : 05/01/2015 8:45 pm
So will the halfords one i found definately fit?
Thanks for your help.
Btw whats the l and r for? Should the l be in the crank side?
Thanks
Posted : 05/01/2015 9:59 pm
On paper yes but it looks suspiciously like a dead one I removed from my commuter after less than 6 months use. it didn't fit so well as it had a big gouge all the way around the body from the screw that holds the bb shell cable routing fitting in place.
Seriously, Shimano. 😉
no idea on the L/R I'm afraid!the threads on both sides (and for the crank bolts) should be RH so I'm not sure it matters. If I'm wrong I'm sure someone will correct me.
Posted : 05/01/2015 10:26 pm
BC 1.37x24T is the thread, British in this case
If L and R doesn't refer to the cup side then it refers to the thread direction on that cup
Posted : 07/01/2015 6:05 am
^ Correct, it is a LH thread on the drive side, my mistake, sorry. 😳
Posted : 07/01/2015 1:28 pm
that makes sense now thanks.
its all back together now with shimano and working like a dream 🙂
now the next problem the rear Q/R is bent! This Vulcan was a VERY bad buy... pretty much everything on it was broken lol
Posted : 07/01/2015 2:44 pm
Are you sure it's a square taper? Most Vulcans I've seen come with truvativ isoflow, which is a similiar format of BB but not compatible with any Shimano bb.
Posted : 07/01/2015 3:08 pm
its got square pedals bit on it
definitely fits like a glove
Posted : 07/01/2015 3:26 pm
