New to tubeless, only done one set last week which was stans flow rims with tape and sealant to a non tubeless tyre, worked fine.
Bought a set of “Bontrager Race Disc Tubeless” wheels on eBay for a hardtail im currently building up.
They have the tubeless valves fitted and what looks like a plastic fitted insert all around the inside of the rim which I assume mates up to a UST bead nicely.
I’m hoping to fit non-ust Nobby Nic Evo’s to the rims, I assume I can just fit them with stans sealant in the normal fashion like you do when fitting to a non tubeless rim (but without the stans / gorilla tape?)
That should work right?
Thanks!
