Trying to source some replacement bolts for bits on my bike. I'm after some help identifying what I need for:
- Shimano SLX shifters (M5x15mm?)
- Shimano XT brakes M785, lever clamp bolt
- Shimano XT M780 Chain ring bolts, triple ring setup
- Caliper brackets (M6x20mm?)
- Caliper to bracket (M6x20mm?)
Any ideas?
Depending on how many you want and how good you are with a hacksaw, for the standard M5 & M6 bolts I'd go to someone like Screwfix and buy a bag of their stainless allen head bolts, then trim to fit.
In fact that's exactly what I did do.
As far as I'm aware any standard chainring bolts will fit your chainset. The last lot I bought (some years ago) were Middleburn alloy ones, red anodized IIRC.
The magpie has bitten though... I'm looking at coloured Ti bolts from http://www.pro-bolt.com/
Tempted to get a selection of 12, 15 20mm bolts and return what I don't use.
The confusion over chain ring bolts comes from them listing 5mm height and 7mm height bolts.
Ah right, you forgot to mention the important bit - you're after pretty colours! 😉
The simplest way of sorting out what size chainring bolts is to remove one you're using now & measure it.
TBH personally I wouldn't bother with ti bolts unless you're a real weight weeny, I'd rather use decent quality stainless for reliability and rust free-ness.
Get aluminium for the first three things - Pro Bolt are good.
XCRacer do good quality reasonably price ti caliper bolts, not coloured, but coloured ti bolts are a bit washed out and rubbish.
Thanks so far.
How do I establish the M size though?
Also, any thoughts on the chainring bolt size?
I've ordered a few M6x20, M6x15, M5x12, M5x15, M5x20.
Will have to find more info on the chainring bolts.
Its roughly the outer (major) diameter of the bolt thread. Easiest to measure with vernier calipers if you have some.
[url= http://www.roymech.co.uk/images/bolt.gi f" target="_blank">http://www.roymech.co.uk/images/bolt.gi f"/> [/img][/url]
