Has anybody swapped out the RL compression damper for a RCT3 damper?
I have a 2016 bluto RL, I’m pretty sure all I need is part no 11.4015.544.270.
There are some threads that suggest the rebound damper also needs to be changed due to the dig valve?
Looking at the spare parts catalog there is only one rebound damper listed for the bluto. So I’d assume that the rebound damper doesn’t need changing?
BLUTO (A1-A2/2015-2017)
16. 11.4018.025.011
Rebound Damper and Seal Head Assembly/Shaft Bolt – Rapid Recovery Reba 27/29, Bluto 26 A1-A3.
13. 11.4015.544.270
Compression Damper, Motion Control DNA, Crown Adjust – SID RCT3 Black (includes compression knobs) A3 2014-2016
