I generally live by the principle of if you need a tool to do a job, don’t get the cheapest but something that will last. (also why I’ve got a garage half full of little used tools, but whatever).
I need a blowtorch to offer some persuasion to a seized screw in end cap on a pump. Cast Alloy casing with alloy 40mm diameter screw in end cap. Confident a little heat will help persuade it to come out without too much drama.
Question being am I going to notice any improvement / better operation between a £30 torch;
https://www.toolstation.com/gosystem-auto-start-blow-torch/p92494
and an £80 torch?
https://www.toolstation.com/vortex-map-torch-pack/p71324
Other than the volume of gas contained obviously.
The cheaper one looks like it might at least find a second life making Creme Brûlée after it’s done it’s intended job.
Thanks
