Has anyone used this from eBay:
Blind bearing puller for hubs
Available in precise bearing sizes, what are the disadvantages over e.g. an expensive kit when I only (currently) want the one size?
Or any advice for similar, reasonably cheap tools? Are any of the kits around £40 on amazon, eBay etc any good?
It’s for a Specialised HiLo 15mm front hub, I’ve tried using a screwdriver but I can’t depress the central tube enough to get an edge on the bearings, and the enduro V type bearing puller similarly can’t find the edge (though was useful for getting the 2 piece bearing caps out, which I failed to achieve with fingers, pliers, or a vice!)
Thanks!
