Not sure if wireless is a priority or not, personally I’ve gone off BT earphones because batteries seem to die at awkward times, plus after a relatively short space of time the batteries will stop charging, and they’ll be junk.
I’ve got several different types of MeeAudio IEM’s, the cheapest ones are remarkably good, although you might need a Lightning > 3.5mm adapter, or a USB-C > 3.5mm one if using a smartphone.
They come with a whole bunch of different size eartips, including double-and-triple-flange, my favourites are the triple-flange.
https://www.meeaudio.com/X1
If you don’t mind spending a bit more, their Pinnacle P1 IEM’s are stunningly good, and use an MMCX connector, so you can buy a separate cable with a remote and either a Lightning or USB-C connector, which don’t cost the earth. MeeAudio don’t do that type of cable, I got mine from a third-party.
https://www.meeaudio.com/P1
