So got the smaller bearings pressed in with a mix of homebrew bar washers and nuts and a mates proper press but really struggling with the bigger bearings on the rear triangle.
The banshee pdf states press from either side of both the new bearings “must be with the linkage in between”….but what I don’t understand is that this linkage provides no bracing at all until the inner races are touching it. So all the force is side to side across what is quite spindly metal. The bearing is v tight and was needing more force than either of us were happy applying so we’ve stopped before we trash my frame.
Ideally you would press the bearing from against the back of the same side you’re installing to remove the above forces (the inside face) but this is not flat, has a cut away on one side and a big weld on the other – so we were not not able to seat the press or washers flat to pull against.
Any tips form other banshee owners before I go tail between legs and a pot of bits to the LBS?
(they’re not banshee dealers so concern is their solution may involve hammers!
