Viewing 12 posts - 41 through 52 (of 52 total)
  • Anything better than mastic tape for chainslap?
  • oikeith
    @rickon did you find a solution that works for you? I have a similiar issue with a new frame and am looking at options from this thread.
    simondbarnes
    I was going to say an old inner tube but it appears that I already did a year ago.
    molgrips
    I had to strip off the old tape on my rigid bike and, wanting to ride it straight away I grabbed the nearest thing which was a roll of insulation tape and gave it three layers. It’s been incredibly durable and is still perfectly tidy three years later.
    rone
    3m 2228
    +1
    eddiebaby
    Singlespeed with a belt drive just to make sure. Or on the Fatty I had a BeerBabe neoprene cover.
    trumpton
    I’ve got neoprene protectors and old inner tubes.
    Fagus
    Inner tube.
    sarawak
    Old Inner tube. Might not look prettiest but works.
    rickon
    Hey,
    Yes I did! I went through loads of solutions – 3228 mastic tape, velcro…
    By a long long way the best solution was some door and window insulation foam like this:
    bedmaker
    This works well. As a bonus, very cheap.
    woots787
    Has anyone tried anything like this
    Garage wall stuff
    I use sticky back velcro at the moment and wondered if something textured like this would keep noise down but not hold the mud as much.
    chrisdw
    Inner tubes dont have to look bad. Grab a thin one or a roadie tube and cut it so its only one layer and about 2 inches wide. Then start wrapping whilst stretching it, overlapping about half of the previous turn like roadie bar tape.
    If you keep it tight it will look quite neat just stick a couple of small cable ties on the ends to stop it moving.
The topic ‘Anything better than mastic tape for chainslap?’ is closed to new replies.
