No idea if I’m right but I tend to use copper slip if it has threads like threaded bb and bolts on bottle cages and mudgaurds and pannier racks etc and if no threads I use grease like headsets, seatposts etc. If it’s carbon, then the special carbon grease stuff.
So far it’s worked fine but I’m sure someone will tell me I’m wrong 😂
Ptfe tape then Grease
If the bottom bracket is the correct size and round then you shouldn’t need Ptfe tape and you shouldn’t be able to fit it if it’s the correct size. But I guess perfect bb sizes are rare so people have come up with solutions. If it’s not round then Ptfe could make it worse where it touches/doesn’t touch.
However, if it’s oversized I can see the benefits of Ptfe tape but ive found my bearings go from the outside, not from the inside. My frame has a drain hole for any water that gets in.
But I haven’t tried it so I can’t really comment but it’s an interesting idea.
