workshop bench trac...
[Closed] workshop bench trackworld (contains chippy content)
11 Users
Folks,
I've decided to tackle the disaster zone that is our garage. One of the things I'm missing is a decent horizontal surface. I started looking for workbenches but they are prohibitively expensive, I want them to be fairly beefy capable of taking something like a landy gearbox etc. So I figured that whilst I'm no joiner I'm not exactly without skills the cost should be slightly lower and I end up with exactly what I want.
I found these brackets online that seem ideal [url= http://www.homedepot.com/p/Simpson-Strong-Tie-RTC42-18-Gauge-2x-Rigid-Tie-Connector-RTC42/100375007?N=5yc1vZaq9x ]Linky Clicky Thingy[/url] bit of an issue finding them in the UK but I think it would be worth it to get them shipped in.
I need to construct freestanding benches, we live in a rental property so I want to be able to move them.
Does any have any experience of this, is it as straight forward as I think it is? Any advice is welcome.
Mutt
Posted : 18/05/2014 7:26 pm
No need for fancy brackets. Just overlap the timber at the joints and screw through. Something like this:
http://www.hammerzone.com/archives/workshop/bench/below20xl.html
Posted : 18/05/2014 7:32 pm
I made a pretty sturdy large bench out of some old roofing joists, using metal joisting brackets (the screw on type) and glue to hold it all together. 2 layers of 18mm WDP ply and then a left over bit of stainless steel screwed on top. So far, unbreakable, but a bit cumbersome and heavy if you want to move it!
Posted : 18/05/2014 7:33 pm
I used 4inch fence posts to make 6legs
75/35 cls franing timber, some left over decking and a sheet of 18mm ply- and used damaged pack laminate on top to preserve surface.
120mm coach bolts and proper joints as above.
Rock solid and heavy as ****. Will post a photo later
Posted : 18/05/2014 7:39 pm
Made this one out of stuff I had lying around. I was in the same position as you this was built in a rented house and now sits in my "new" garage.
Posted : 18/05/2014 7:53 pm
There you go. Simple enough?
Posted : 18/05/2014 8:21 pm
Cheapo fire-doors make brilliant workbenches. Attach back length to a bit of timber attached to solid wall, support front corners. Done.
Posted : 18/05/2014 8:31 pm
I built the one that nickjb linked to but I used an offcut of kitchen work surface that I got from B&Q for a £5 for the top.
Find your local second hand tool shop and get a Record vice as well. I think I have a number 23
Posted : 18/05/2014 9:07 pm
top tip, when completed coat all visible surfaces with water based clear varnish 2 coats, drys quickly and stops all those anoying greasy/oily hand prints.
Also a sheet of hardbaord fixed on top rough side uopp will protect the top and is easily replaced when damaged, the rough side also stops stuff sliding around.
Finally a piece of wood ful length about 3 inches high screwed on back edge will stop disapearing over the back of bench
Posted : 18/05/2014 9:12 pm
Still wip , tools still out as wiring it up for electrics to the rear ply face.
Dont have any pics of it finished.
Here is mine, fence post legs & 4"x2", i added some more supports for the top and vice which i got for £7.50 from ebay
Pretty solid.
Posted : 18/05/2014 9:14 pm
great ideas so far... ignoring one who didn't read the OP specification... (cough cough)... 😕
landrover bits aka about a ton of LT75 gearbox and transfer box..
now what about bike storage, I'm thinking vertical, as in on end, front wheel / rear wheel alternating on the opposite wall, i know i could do hooks into the ceiling / wall but i'm fancying something mobile and flexible.
thoughts..
Posted : 18/05/2014 9:28 pm
top tip, when completed coat all visible surfaces with [s]water based clear varnish 2 coats, drys quickly and stops all those anoying[/s] greasy/oily hand prints so it looks like a proper man bench
Posted : 18/05/2014 9:29 pm
was fancying covering the top in aluminium sheet or maybe steel to stop the marks..
deffo a big vice (has to be record anything else simply isn't cricket) :mrgreen:
Posted : 18/05/2014 9:32 pm
lol, sorry I did miss the freestanding bit. To be fair, the fire-door still makes a class work-surface: big, strong, smooth, square and importantly: cheap. Even fancy ply surfaces have warped on me in the past, any of the "door" based benches I've made are still perfect.
Posted : 19/05/2014 8:25 am
mine is pretty much the one nickjb has pictured. Ability to hold a land rover gearbox dependent only on what you surface it with. Built mine with 4"x2".
Posted : 19/05/2014 8:42 am
