Woody Folk Help Ple...
[Closed] Woody Folk Help Please Replacing window mullion.
5 Users
Hoping someone can help. Started a window repair as a bit of sanding, fill and paint and turn into a major refurb. So needed to replace one of the mullions. So far I have removed the rotten one and made a length of same profile to refit. Now as both ends are only accessible from the inside . So how do I fix each end in place, is it a glue and screw or is there some sort of joint I can do ? I was looking at loose tenons but it seems I need access to both sides is this true ?
Any help please Simon
Posted : 25/04/2020 10:31 am
I've always tried to scarf it when I've let a new piece into a rotten member. Glue and screws are fine if that's possible. Filled with a 2-part wood filler.
Got any pictures?
Posted : 25/04/2020 5:01 pm
window
Posted : 26/04/2020 9:36 am
Cheers Kayak for responding .
Replacing the centre left mullion and it was easier to make a new one than repalce rot at bottom. I should of replaced it before the top cill went in but did not decide to until all those cills were screwed and glued in place.
Posted : 26/04/2020 9:41 am
window
Posted : 26/04/2020 9:42 am
window 2
Posted : 26/04/2020 9:44 am
Doesn't look too bad in the picture. I'd try and keep as much of the original as possible. I gave mine a good soaking of wet rot wood hardener, then routered out the bits that were still bad, then glued a couple of smaller bits into the routered out area.
If it really is beyond that then I would still try and keep the top section. Make a new bottom piece. That can tenon into the sill, then scarf it to the original top half. Glue, screw and filler.
Posted : 26/04/2020 9:47 am
 piha
I would look to fit a replacement mullion from the inside and cutting a simple tenon joint to help with retaining frame strength and supporting the weight of the window.
Posted : 26/04/2020 9:51 am
Went for a glue and screw in the end
mullion in
Posted : 26/04/2020 5:04 pm
Main problem is the mullion is tapered at the front so only can slide in from front.
Thanks for giving me the reasurance to pop it in.
Cheers Simon
Posted : 26/04/2020 5:10 pm
Looks really good..Nice one 👍
Posted : 26/04/2020 6:03 pm
Looks like you've done a nice job there. If you need to carry out any future repairs, I would recommend Timbabuild EHB60. I always use it when I'm repairing windows. It bonds incredibly well to the old timber once prepped and is flexible, unlike 2 part filler.
Posted : 26/04/2020 6:57 pm
