Windows XP help
[Closed] Windows XP help
2 Users
My Laptop running XP with SP2 is a bit rubbish at starting up and routinely takes 2 or 3 tries to get going. Occasionally (i.e. this morning) it really struggles and takes 10+ times. If you try starting it in Safe Mode, it doesn't always work (hangs when trying to load ...Mup.sys - I googled this and people talked about BIOS and things I don't understand)
Now it's running, is there a way I can find out what's wrong with it? I don't think it's a virus or spyware but some other sort of problem.
"Buy an apple" isn't helpful advice, and I would if I had the spare cash!
Posted : 05/09/2009 9:12 am
It maybe because you have too much "rubbish" being loaded in the background.
Click on the start menu, click Run,then type in "msconfig".
This will bring up a window. Click on the start up tab, this will show all of the stuff that windows loads in the background. For instance Adobe Acrobat viewer kindly installs a widget that makes sure you have the latest version, you don't really need this.
Uncheck the items that are slowing your PC down, you may need to perform a little trial and error here. You could also do the same with the Services tab.
You do need to be careful as you could stop something loading like your anti-virus from loading.
Posted : 05/09/2009 9:17 am
Seems to be a lot better after that. Thanks mate
Posted : 05/09/2009 9:34 am
