Wheel barrow. Solid...
[Closed] Wheel barrow. Solid or pneumatic tyre?
23 Users
General gardening duties and moving logs around. What is the best tyre choice?
Posted : 07/05/2017 8:03 pm
 Yak
Pneumatic.
Think about the roll-over and bumpy ground with a heavy load.
Posted : 07/05/2017 8:04 pm
Pneumatic.
Posted : 07/05/2017 8:06 pm
Solid. If it's for infrequent use be flat every time you come to use it otherwise.
Posted : 07/05/2017 8:12 pm
foam
Posted : 07/05/2017 8:14 pm
i have both
much prefer the pneumatic one. much more comfy to push and goes over square edges easier - no punctures and haven't had to pump it since buying it 2.5 years ago.
could fill the tube with latex i suppose if i wanted but have never bothered.
Posted : 07/05/2017 8:33 pm
I have five, 4 pneumatic, one solid. Solid is utter pants, noisy and unpleasant to use. They all live outdoors and on site. 1 puncture in 10 years
Posted : 07/05/2017 8:37 pm
Pneumatic. Much nicer over the bumps and small steps. Probably pump it up once a year, maybe every other. No big deal, just use the track pump.
Posted : 07/05/2017 8:50 pm
you can get Puncture free wheels that aren't solid.
Posted : 07/05/2017 8:59 pm
Don't forget to set it up tubeless and ~4psi. 😉
Posted : 07/05/2017 9:09 pm
Pneumatic but you got that already. My wheelbarrow has just expired at a decade old and the wheel and tyre are fine. Had a couple of punctures along the way.
Posted : 07/05/2017 9:59 pm
FastYoungGit bought a cheap one with a solid tyre. Full of logs it's constantly bumping over stuff that mine, which has a decent tyre, would glide over. I think it would do more damage to a lawn, also.
In case you needed more confirmation.
Posted : 07/05/2017 10:09 pm
We've got solid for home but tbh it mostly gets used on smoothish surfaces so it's not that bad. If I was using it on the sort of surfaces we barrow over when trailbuilding, it'd be horrendous though.
Posted : 07/05/2017 10:24 pm
Mostly pneumatic here, full of logs they bump over stuff better.
The lads working on the hill got a solid wheel barrow, we took the piss a lot, but amazingly it is still in use and they haven't lost it.
Posted : 07/05/2017 10:25 pm
As above, pneumatic bumps over obstacles better when there is some weight in it.
Posted : 07/05/2017 10:33 pm
Awaits wheelbarrow pic with +tyres and boost hub.
Posted : 07/05/2017 10:36 pm
Pneumatic.
I pump mine up once every few years and it's lasted 15 years so far, living outside. Was a decent trade barrow (when I bought it), now battered to f***.
Posted : 08/05/2017 9:48 am
Isnt there a Wheelbarrow forum for this sort of question ?
Posted : 08/05/2017 9:56 am
I can't believe its not butter, this site is full of mountain bikey folk would you ever contemplate a solid metal tyre bike or even a foam made tyre/wheel it doesny work
It turns but its rubbish if there's no air but i suppose no puncture to repair even thats easy to repair, the barry normally rusts before it ever punctures
Posted : 08/05/2017 11:08 am
Is this the worst post ever?
What tyres for a wheelbarrow? Seriously?
Posted : 08/05/2017 11:11 am
I've got a Solid wheeled one that was buiried at the bottom of the garden when we moved in...
I would heartily recommend a pneumatic tyre if you are likely to use it more than three times a year.
Of course it opens up a wide world of opportunity for more questions:
Can I run tubeless for optimum ride/weigh saving on my wheel barrow?
What Wheel barrow 'Plus' tyre?
What pressure do you run in your wheel barrow tyres?
Posted : 08/05/2017 11:29 am
[i]What tyres for a wheelbarrow? Seriously? [/i]
IIRC, ask the tyre shop to fit a six-ply industrial. I believe they come with a two-ply.
Posted : 08/05/2017 11:30 am
As Duncan from dragons den would say i'm out
Its like a Harry Enfield sketch with Brian and business partner Ken on dragons den
Posted : 08/05/2017 12:08 pm
How have we go to post #24 and nobody has suggested a Hoverbarrow yet?
Posted : 08/05/2017 12:13 pm
I have pneumatic and run them at way lower pressure than you 8)
Posted : 08/05/2017 12:25 pm
Mine has a carbon rim. And lock on enduro grips.
Posted : 08/05/2017 1:16 pm
 Yak
Skinwall ftw 8)
(not really)
Posted : 08/05/2017 1:19 pm
Mine perished many years ago, could use some lockons now...
Posted : 08/05/2017 1:25 pm
obvs
Posted : 08/05/2017 1:35 pm
