What's wrong w...
[Closed] What's wrong with my hot tap?
10 Users
Bathroom basin
All OK when it's first turned on but gradually over 60 seconds or so the flow rate reduces to a trickle
All other taps in the house OK
Posted : 03/06/2017 9:34 am
what kind of tap? old fashion pillar (turn handle loads of times) or a modern ceramic valve (1/4-1/2 turns to open or close)? Mixer or single supply?
Posted : 03/06/2017 10:56 am
 Bear
If washer type tap they can sometimes expand when the hot water comes through and flow reduces.
Posted : 03/06/2017 11:11 am
Old fashion pillar type
Posted : 03/06/2017 11:27 am
 DT78
Maybe an airblock? Had this in my kitchen tap. Opened upstairs hot tap and forced cold water through hot feed to get rid of it.
Posted : 03/06/2017 11:28 am
Sounds like an airlock.
If you have a kitchen mixer, try forcing cold up the hot side of the tap, with the upstairs hot tap open.
Posted : 03/06/2017 12:01 pm
Sorry I'm being thick but how do you force cold water through the hot tap?
Posted : 03/06/2017 12:13 pm
Are any of the other hot taps showing any signs of doing the same, even if it's just a slight reduction in flow?
Posted : 03/06/2017 12:22 pm
Hot water cylinder? Airlock ^^^
Combi boiler? Faulty tap??
Several online guides via google
Posted : 03/06/2017 12:28 pm
Yep, mine only does that when the HW cylinder needs draining and 'recharging' - 5 minute job normally (only applies to mains pressure type cylinders).
But in those situations it affects all the taps to some degree, although one (which requires higher pressure to work) does reduce to a trickle.
Posted : 03/06/2017 12:33 pm
Do.you have a kitchen mixer tap?
Posted : 03/06/2017 2:30 pm
If you have a mixer anywhere in the house, put your palm over the spout tightly, open the hot and then open the cold to use the mains cold water pressure back up the hot supply.
Posted : 03/06/2017 3:06 pm
We have a lots-of-turns mixer tap in our utility room that does the same thing; I thought it was a plastic washer expanding when the hot water comes through. It's just a fairly cheap tap, ones with ceramic washers don't do it.
Ours is a combi boiler, there's no air in it.
Posted : 03/06/2017 8:25 pm
Make sure you don't have a pressure compensator on the system - it needs to read 3bat when the tap furthest from the system is open and running.
Posted : 03/06/2017 9:29 pm
