What's new and...
[Closed] What's new and happening in the espresso machine market. (Not a gaggia classic)
My trusty coffee machine is falling to bits, I've had it and over used it for about 15 years now.
I have a separate grinder, but I'm at a loss at what should be replacing the coffee machine.
I'm aware there's lots of snobbery on here so let's have a top ten run down please.
I'm not wanting to spend more than £300. But when has that stopped me spending more!
Posted : 18/10/2016 1:41 pm
If it was me, I'd go for a lever machine like a europiccola, more interesting in looks and operation than a boring old pump machine.I am biased though 🙂
Posted : 18/10/2016 2:17 pm
Sage Duo Temperature Pro?
Posted : 18/10/2016 2:19 pm
Sage. Or if you like fiddling a Londinium L1 (unfortunately their 'budget lever' is still in development)
There are a few other machines out there with th e-61 group from the likes of isomac, faema expobar, quickmill etc worth looking at too
Posted : 18/10/2016 3:26 pm
I'm selling a practically new DeLonghi Caffe Corso?
I paid £280 for it. Looking for £150 ono (Must collect from Manchester though)
Posted : 18/10/2016 3:41 pm
Does that come with a free Porsche Maccan?
EDIT: And yes I'll be the first to say..
Because I've yet to have coffee from one of these machines that tastes better.
Posted : 18/10/2016 3:43 pm
A classic is still the best option under £300. There are loads available second hand that usually just need the shower screen and block removing for a good clean and descale.
Posted : 18/10/2016 3:47 pm
I bought myself a sage duo temp pro a couple of weeks back and so far I'm impressed. It's my first espresso machine and while it's a bit more faff than I expected the coffee I'm getting from it is excellent so far.
Posted : 18/10/2016 4:21 pm
Jimmy. I've got one of those but the coffee is only ok and full of grounds. I'm using lavazza ground coffee. I have a grinder and beans, so can do the grind myself if required. What do I do?
Sorry op for the hijack
Posted : 18/10/2016 4:26 pm
Hijack - what;s the best burr grinder to use with my Classic? After putting up for several years with a Dualit that can't grind fine enough I was thinking about asking Father Christmas for a new one.
Posted : 18/10/2016 4:55 pm
Posted : 18/10/2016 6:39 pm
Grinder - I would go with the Rancillio Rocky myself. I used one for years (still down in the garage for when I abandon the bean to cup... although the Sage Oracle is filling me with lust now!)
Posted : 18/10/2016 6:55 pm
[b]r8jimbob88[/b] - you still got that caffe corso?
I'm in Manchester, would happily buy it off you.
Posted : 18/10/2016 7:41 pm
What Jimmy said.
You need a fine grind, but not so fine as it pisses through the filter. Dunno what you're doing wrong but I've had no issues with grounds ingress.
You do need to take it off the heat immediately when it starts spluttering; if the water runs out and you force steam through it it gets bitter.
Posted : 18/10/2016 8:15 pm
Tried that it was still cack compared to the Silvia. This was with freshly ground coffee and a slightly coarser grind than the espresso machine.
Posted : 18/10/2016 8:19 pm
I am well happy with my Sage Duo, especially as there was £50 off. Put that towards the Sage pro grinder.
Posted : 18/10/2016 8:45 pm
Has to be max stw points.
Posted : 18/10/2016 9:14 pm
