What was that Mesh ...
What was that Mesh system on Amazon?
Apologies, I saw a thread a month or so ago that recommended a cheap mesh system on Amazon - someone linked it then several people concurred it was a good buy.
(I did try searching, but got the normal four year old threads)
Cheers...
Posted : 18/09/2023 6:05 pm
TP Link Deco?
Posted : 18/09/2023 6:08 pm
Cheers...there's this one at nearly half price
https://www.amazon.co.uk/TP-Link-Deco-E4-Seamless-Replacement/dp/B07RXLF5XZ/ref=sr_1_5?keywords=mesh+wifi&qid=1695052857&sr=8-5
It's just to get better coverage in my study - router and current extenders are the other side of the hall so I guess I don't need anything too fancy.
Posted : 18/09/2023 6:12 pm
Jesus...there's a
- TP-Link Deco S7 AC1900 at £79.98
- TP-Link Deco S4 AC1200 at £94.98
- TP-Link Deco E4 AC1200 at £84.99
I presume the S7 is the best one?
Posted : 18/09/2023 6:18 pm
I've got a Tenda MW3, I think based on recommendations from here. Had it for years now and can't fault it, could that be it?
Posted : 18/09/2023 6:24 pm
 nuke
^^^I think Bails has it in that it was the Tenda MW3 that was recommended....I read the thread and have been indecisive between the MW3 (been out of stock for a while but did come back in stock last week) & MW6 (which was circa £80 on Amazon but is over a ton at the moment)
Posted : 18/09/2023 7:37 pm
Had a Tenda MW5 for two years and it's been great until the last couple of weeks when my work PC has lost connection on a few occasions. Need to figure out why, but plugging in an ethernet cable has worked when it hasn't immediately reconnected. Phones have kept their connection fine.
Posted : 18/09/2023 7:40 pm
CeX had a load of tendas. I bought one (MW6) from there after the last thread and it's been great so far.
Posted : 18/09/2023 8:19 pm
Mercusys on Amazon is TP-Link in all but name. Works fine for me in a house that struggled with WiFi in the past and cheap enough for the Wifi6 version.
Also usefully confirmed that the crap Wi-Fi and random dropouts I’ve been experiencing are solely due to the pair of Google WiFi pucks that it’s replaced.
Posted : 18/09/2023 9:05 pm
I had the Tenda MW something or other - three of them have great coverage all over the house.
UNTILL a neighbour setup a network on the same channel (probably also a Tenda) Which knobbled the speed. There’s no way to change channel like you can on any halfway decent router. So - they’re bugger all use of you have neighbors
Posted : 18/09/2023 10:19 pm
Cheers all, I am an end terrace so have neighbours...although I think she's about a million years old.
Not sure I understand the numbers, but the MW6 looks good, as does the 1900 to link one.
Posted : 18/09/2023 10:28 pm
Make sure they can handle your connection speeds ie not all mesh systems can do high mbps
Posted : 18/09/2023 11:18 pm
I’ve got a tends mw6 mesh. It’s good but the app needs a bit of work. Our ring system seems to often lock onto the node furthest away with the weaker signal. If only you could lock fixed items to fixed nodes it would be great. Otherwise pretty reliable and trouble free.
Posted : 19/09/2023 12:28 am
The Deco app wasn't the best - but it was upgraded a few months ago , which means not only can you lock a device onto a certain node , but you can force / prioritise the others.  I have some Sonos speakers in the kitchen that seem to want to be serviced by the Deco in the attic.
As mentioned above - you cannot manually change channels
Running dual band can confuse them
Posted : 19/09/2023 9:53 am
TP link Deco M5 here and they have been faultless for a good few years; garden, extension and wherever we need it. Both me and my wife mainly work from home and we are always on video calls at the same time with zero connection issues. 🙂
Posted : 19/09/2023 10:07 am
 nbt
MW3 is fine for most people. If you have fast intenet (over 100mb) then you need an MW6 base unit to take advantage of the higher speeds. though you can use the MW3 nodes once the MW6 base unit is in place.
I have a Tenda MW3 system and only use 2 out of 3 nodes in a 3 storey 4 bed house, they're quite god that way.
I got a Mercusys for my dad - it's not as easy to set up  / manage, and every once ina while it will randomly have a meltdown and stop working, but is fine after a reboot. It was about half the price of the Tenda setup
Deco S4 here. 3 nodes around a 4 bed semi. Coverage everywhere, easy to set up and no issues since getting it about a year ago. No problems with speed but we're only on a ~30mbps connection to begin with.
Only slight issue is that you can group devices to a person so you can set limits on a child etc. But, it's surprising how many devices show up as "unknown device" rather than an indentifiable name so you then have to start a process of elimination to work out what it is.
Posted : 19/09/2023 2:17 pm
Apologies for the thread resurrection, but is this any good:
Deal: Tenda Nova AX1500 Whole Home Mesh Wifi 6 System, Up to 3200sq ft Coverage, Dual-Band Wi-Fi Mesh with 2 Gigabit Ports, Compatible with Alexa, Parental Control and Easy Setup(MX3)3-Pack https://amzn.eu/d/dKC3Hth
I’m considering trying to get wifi to the garage which is 30m away, we have a shed with power half way down garden.
A long cable would haveto go over the house as it’s a little terraced house with long garden.
And of course the wifi gubbins is at the front wall.
Thinking about trying that cheap smart trainer in the garage.
Posted : 20/01/2024 10:22 am
Apologies, I’ve ordered a Tenda set up, sounds like it will do the job.
Posted : 20/01/2024 12:17 pm
