What Soldering Iron...
[Closed] What Soldering Iron?
I've got some soldering to do (Christmas present that requires soldering!!) and so need a Soldering Iron. It's a few years since I've needed to do any soldering, but as with most stuff there's a slightly baffling selection online, please recommend me a good budget soldering iron for an amateur (I'll also need solder so a beginner kit may be good). Thanks.
Posted : 28/12/2013 12:07 pm
If I were you I'd go for a butane one. The one I had (since lost in a move) used standard, compressed, lighter fuel.
I think it came from screw fix. It was much better than the ones I'd used at college and the lack of cable was a real bonus.
I hope that helps.
Posted : 28/12/2013 12:23 pm
I've got one very similar to this
http://www.maplin.co.uk/p/pro-iroda-solder-pro-70-gas-soldering-iron-n95ap
Very useful, heats up quickly and can use anywhere as it's not a corded electric. Be careful if you're soldering near something flammable though!
Posted : 28/12/2013 12:26 pm
A mid sized Antex for around £10-£15 will do the job. Best to get a stand as well or you will burn something you shouldn't. This is good for the money, too: http://www.maplin.co.uk/p/50-w-solder-station-n78ar Has a built in stand and a good range of temperatures.
Posted : 28/12/2013 12:27 pm
Are we talking silver soldering or soldering as in PCB's. If electrical Antex are great. Use good fluxed solder.
Posted : 28/12/2013 12:29 pm
Plug in mains if you can work at a bench/table something like the Antex is good, otherwise for playing with automotive use a gas one is invaluable as you don't have the cable in the way, and you can do shrink wrap with it as well.
Posted : 28/12/2013 1:00 pm
Depends what you want it for.
I got a controllable job form Maplin which is great. With the right temp/tip I can go from soldering SMD onto home made pads (lower heat, smaller tip, fiddly) to soldering leads onto the back of pots (lots of heat needed).
This one - http://www.maplin.co.uk/p/60w-professional-lcd-solder-station-with-esd-protection-a55kj
I wouldn't use a gas iron unless I was outside or needed portability. Get yourself a solder sucker and some braid while you're down there. You may need a heat shunt depending on what it is your soldering.
If you don't want to spend that much, the Antec 18w will do you nicely.
I want it for soldering PCB's -my wife got me a [url=
Box Kit[/url], but I also plan on using it while getting my old remote control car working for the boy.
Posted : 28/12/2013 1:32 pm
get a maplin one for that sort of thing, I wouldn't use a gas as they are hard to control, but guessing that the pcb is a pth then an electric one will be fine I've used the maplin ones and they are not brilliant but do what you need.
Posted : 28/12/2013 1:45 pm
JEngledow - Member
I want it for soldering PCB's -my wife got me a Useless Box Kit, but I also plan on using it while getting my old remote control car working for the boy.
POSTED 2 HOURS AGO # REPORT-POST
That's Awesome 😀
The £20 maplin job will be perfect. Pickup some solder, braide, a solder sucker and a heat sink while you're there. Assuming you have wire strippers you're ready to crack on. A stand for the iron would be good too.
Posted : 28/12/2013 4:34 pm
