What settings have ...
[Closed] What settings have I inadvertently changed!
I used to see Youtube Videos as a picture from the film with a play-arrow in the middle when they were embedded into forum posts. For the past few days I just get a plain white box the size of the old video/picture with the link underneath. Clicking on the link takes me to You tube and I can view the video. No idea why the old way no longer works. I didn't change anything (that I recall) and cannot find any way to alter it.
Ideas?
Posted : 29/03/2015 9:16 pm
chrome?
Posted : 29/03/2015 9:19 pm
Check if you have Disable Script.
Enable Script (only if you trust the site) will allow you to see the way you used to see Youtube in forum.
I use Firefox and I set my default to Disable Script so I see a blank with a link at the bottom. If I want to see the picture as you described I would have to click "Enable Script".
Posted : 29/03/2015 9:24 pm
Yep, Chrome
Where do I find the Disable Script?
Posted : 29/03/2015 9:28 pm
[url= http://browsers.about.com/od/googlechrome/ss/disable-javascript-chrome-windows.htm ]Some info here.[/url]
"If you'd like to turn JavaScript off or on for all sites:
Click the Chrome menu Chrome menu in the top right hand corner of your browser
Select Settings
Click Show advanced settings
Under the "Privacy" section, click the Content settings button.
In the "Javascript" section, select "Do not allow any site to run JavaScript" or "Allow all sites to run JavaScript (recommended)""
Posted : 29/03/2015 9:31 pm
Hmmm, checked that and all is set to the recommended settings ie allow all sites to run Javascript..
I have not changed any of those settings in ages. Embedded videos work fine in other sites (forums and FB) so seems confined to STW for some reason.
Will keep looking. Thanks for help so far guys
Posted : 29/03/2015 9:37 pm
[quote=welshfarmer ]Hmmm, checked that and all is set to the recommended settings ie allow all sites to run Javascript..
this happened to me couple of weeks ago, I never changed anything not sure if it was an update to chrome that caused it. Have you checked the settings? what version of chrome are you using.
[url= https://support.google.com/chrome/answer/6138475?hl=en ]https://support.google.com/chrome/answer/6138475?hl=en[/url]
Posted : 29/03/2015 9:40 pm
Firefox is fine here with STW when I enabled or disabled script but I am not a Chrome user.
Check you Add-On extension perhaps?
Posted : 29/03/2015 9:44 pm
Hmmm, just remembered, I chose not to download the latest adobe flash player update the other day as my connection is so slow I needed bandwidth for doing other stuff. Maybe that is the issue as I think this problem arose at around that time.
Posted : 29/03/2015 9:55 pm
I only have Adobe [b]Shockwave[/b] Flash 16.0.0.305 (latest) at the moment. i.e. not Adobe Flash Player ... bloody confusing they are.
But when I reboot my PC, yes, Adobe Flash Player would ask me to update player but since I don't use that I just ignore it.
I am slowly trying to get away from Adobe and waiting for the right format to appear.
Posted : 29/03/2015 10:01 pm
Hmm, done the update, no change. Back to the drawing board
Posted : 29/03/2015 10:14 pm
Just updated my Adobe Shockwave Flash to 17.0.0.134 ... ๐Ÿ˜€
Not sure what has happened to your Chrome. ๐Ÿ˜•
Posted : 29/03/2015 10:26 pm
