What in-line bathro...
What in-line bathroom extractor fan do I need?
10 Users
8 Reactions
HIB one appears to have suffled off this mortal coil. Didn't last particularly long so not hugely keen to replace like for like.
Apart from knowing what size I need (which will involve a trip to the loft) are there a couple of decent brands out there to look for? (Once I've checked all the usual stuff to ensure it has indeed failed and not just got a bird stuck in it or fused blown...)
Posted : 11/01/2025 9:18 pm
I think the standard answer is Manrose MF100t (or you can get the one without a t if you don't want a timer)
We've only had ours a couple of years but no issues at all.
Posted : 11/01/2025 10:37 pm
chambord and chambord reacted
I fitted a Vent Axia today. Very quiet. Main thing to match is if the old one had a twin core cable or a triple core cable. Twin is the basic fan and triple will be for an over-run one.
I found out the hard way..
Posted : 11/01/2025 11:53 pm
kelvin and kelvin reacted
Op username checks out.
Posted : 12/01/2025 8:40 am
I fitted an Xpelair last year and not had any issues. Picked it as it’s meant to be quiet, but TBH I don’t notice it’s any quieter than the one it replaced.
Posted : 12/01/2025 9:21 am
Humidistat version seem to die quicker than over run timer versions.
Look for something under 40db , mount it off the rafters if you can by hanging off 4 wires , be way quieter.
Also look at flow rate V noise and always ensure air can get into the bathroom under the door or the fan won't draw against a vacuum efficiently
Posted : 12/01/2025 9:32 am
 NS
Manrose (as already mentioned) - had them for many years with no issues & they are not expensive.
Make sure you use insulated flexible ducting rather than rigid plastic - will be much quieter. You can also alter the fan speed to deal with any noise.
Posted : 12/01/2025 9:48 am
 csb
It is quite freaky how often a topic on this forum pops up that is exactly the issue or dilemma I'm having. Bizarre.
Posted : 12/01/2025 10:20 am
It is quite freaky how often a topic on this forum pops up that is exactly the issue or dilemma I’m having. Bizarre.
Same thing happened to me when the Picolax topic popped up
Posted : 12/01/2025 12:32 pm
The Manrose and insulated ducting clearly work at ours, it’s 5m long and 6” diameter.   Just need to put back the vent which seems to have come dislodged…
IMG_1778
Posted : 12/01/2025 4:04 pm
