hi
after making a turntable shelf - gf likes neat, stylish etc things, I want something that will reliably support a fairly heavy 50cm deep turntable (so shelf 50cm x 50 cm) (to brick wall)
trouble is wall mounts need to be neat, stylish and she likes glass and for style reasons the large, functionally effective, cheap large L shaped brackets are out ........
any ideas ?
Thanks
Nice big heavy duty ones from Wickes....
And either MTFU or get a new GF....
just get her to hold it if she's that fussy
piedi di formaggio - Member
And the shelf....
Love all the comments above
Quick search on google
50x45 shelf with support for AV equipment
Not sure if stylish enough though
http://www.chaseavdirect.co.uk/unicol-avp2-avecta-optional-metal-shelf-45-x-55cm.html
Oooppps my bad it looks like it slots in to a fitting of some sort
http://www.glassshelf.co.uk/floating-glass-solid.shtml
Or
http://www.dmgglass.com/glass/shelves/SC5.html
(oh, and 50cm deep gf?)
thanks guys
off to get some duct tape .....................
I've used [url= http://www.ironmongerydirect.co.uk/products/shelving_and_storage/shelving_brackets/251001/shelf_support_bracket_pelican_/337887 ]these[/url] before and they're OK if the wall is sound. If there's a gap between the plasterboard and the brick I wouldn't use them though.
You're into brick so you could do a floating type bracket - screw threaded rod into drop-in anchors then depending on the thickness of your shelf either drill holes to slot onto the rods, or put a couple of o-rings on each rod and sit shelf on top?
