Very long shot
[Closed] Very long shot
10 Users
Anyone have a plasterboard lift hoist thing I can borrow in W.Yorks area?
Kind of need asap and don't really want to buy one; HSS don't seem to have as an item for hire.
Posted : 25/02/2014 9:24 pm
other hire shops are available.Lol
Try using the smaller sheets of plasterboard from B and Q, lot easier to work with and less waste if you snap one, which happens on larger sheets.
Posted : 25/02/2014 9:28 pm
http://www.hss.com/g/69940/Panel-Lifter.html
Posted : 25/02/2014 9:30 pm
Smaller boards
Posted : 25/02/2014 9:34 pm
Ahh, cheers. 12.5mm big ass sheets already bought. That's quote pricey for hire; might just by one for £350 off ebay and rent out myself!
Cheers though, didn't know they were called that.
Posted : 25/02/2014 9:35 pm
Hire a dude to help you lift.
I have done. The sheets are 8ft heavy ****ers though,and we have a lot of ceilings to do!
Posted : 25/02/2014 9:43 pm
Cut sheets in half?
Posted : 25/02/2014 9:46 pm
http://www.amazon.co.uk/FoxHunter-Quality-Mobile-Drywall-Plaster/dp/B00487PA42
Buy it then sell it on after use
Posted : 25/02/2014 9:51 pm
 Bear
make ea couple of dead men.....
Posted : 25/02/2014 9:52 pm
How high area the ceilings? I do 8ft boards on my own, I only struggle at 2.5m+.
Make yourself a T shape prop, about 30mm longer than your ceiling is high, your a piece of heavy string/light rope to the top. Put the prop around a third of the way into the boat gently at first so you can position it, then screw up the other end you are holding. Easier with hop up stands rather than steps. I also use a quick action adjustable prep at the free end and an autofeed screw gun. The props are about 12 quid at screwfix, autofeed gun makes things a lot quicker and easier but I used to do it without.
It WILL take a fair bit of practice to get the knack. If you can't mange, just half them.
Posted : 25/02/2014 10:05 pm
What he said above
Posted : 26/02/2014 1:54 am
Gyprock is heavy? 😆 are you a bird? 😆
Posted : 26/02/2014 4:41 am
Posted : 26/02/2014 7:34 am
