Urgent boiler advic...
[Closed] Urgent boiler advice
5 Users
Had the boiler serviced last week and has been running fine. Just gone to bed and the system is making funny noises - checked the boiler and sounds like there is air in the system. But the boiler keeps running a cycle of firing up, running until it sounds like the air hits the boiler then shuts down. Then repeats.
I've turned the boiler off - does anyone know if this is OK without turning the gas off? The manual says when I shut it down to turn the gas off too but I don't know if this is for longer periods. I'll get the plumber round in the morning to look at it.
B
Posted : 22/11/2009 10:44 pm
 Bear
Thata fine, just isolate electricaly and it will be fine.
Posted : 22/11/2009 10:45 pm
You mean unplug it?
Posted : 22/11/2009 10:47 pm
just unplug it, pilot wont light, gas valve will close
Posted : 22/11/2009 10:49 pm
 Bear
If that is what will isolate it then yes. It will not be able to fire up with no electrical supply to it. (assuming it is a modern wall mounted boiler!)
Posted : 22/11/2009 10:50 pm
Yeah - modern wall mounted boiler. A ferroli.
Bit worrying since its in the kids bedroom 😕
Right gonna unplug it and go to bed.
Posted : 22/11/2009 10:51 pm
 Bear
that will be ok, get it checked out properly in morning, good luck, although sounds like nothing too serious (keeps fingers crossed for you!)
bad luck for having a ferroli tohugh!
Posted : 22/11/2009 10:54 pm
Are ferroli that bad??? Came with the house 🙁
Just got up and bleed all the radiators - one nearest the boiler let out air for about 60 seconds. Just turned boiler back on and gonna monitor it.
Posted : 23/11/2009 7:20 am
Topped pressure back up?
Posted : 23/11/2009 8:36 am
 jedi
i was just going to recommend paulosoxo and he turned up 🙂
Posted : 23/11/2009 8:38 am
Yep, pressure was way down once the rad was bled so topped it back up to where it was before.
I think the problem was last night I realised one of the rads downstairs was off and had been for a long while - turned it on and thats when it started making the funny sounds.
Posted : 23/11/2009 10:37 am
Cheers Jedi! 🙂
Posted : 23/11/2009 11:47 pm
