TV speakers / home ...
[Closed] TV speakers / home cinema thoughts pls
8 Users
 Aus
We've a Toshiba Regza LCD TV. Picture's fine, but the sound quality is pretty poor. We only tend to watch a bit of TV (via Freesat) - very few DVDs.
If we want to improve the sound, what's an easy and cheapish way of doing it? 5.1 home cinema systems seem a bit excessive for Match of the Day and Location Location Location! 2.1 systems make more sense, but worry they'll be very base-y. Often home cinema stuff seems to be maximised via blue-ray, of which we never use.
Is there a simple way of just adding a couple speakers, akin to simple PC speakers?
Posted : 05/01/2011 3:31 pm
most 2.1 drivers have base & treble adjustments so you can dial it as you want.
http://www.scan.co.uk/products/logitech-s220-21-speaker-system-black-17w-rms
£18
http://www.scan.co.uk/products/creative-inspire-t3130-21-speaker-system-black-20w-rms
£37
Id think about something like these ^
Posted : 05/01/2011 3:34 pm
I wouldn't say there would be much point adding anything akin to PC speakers, however a couple of small bookshelf audio (not AV specific) speakers run through a stereo amp would widen your soundstage and give more depth and presence to your current tv speakers.
 Aus
thanks. Stoner - we've got a couple of Creative bits and bobs and impressed with them. The speakers you're suggesting, do they just plug into the TV audio ports - job done?
Posted : 05/01/2011 3:54 pm
as above simple answer
Posted : 05/01/2011 3:55 pm
I disagree. I've got some on our media PC and they work very well - and we have another set in the front room plugged straight into the big TV since we have exactly the same problem as you - eg crap built in speakers
Posted : 05/01/2011 4:04 pm
 br
While you may not do much at the moment, with better sound...
I went for a separate amp and 5.1 speakers.
This kinda thing:
http://www.richersounds.com/product/av-receivers/sony/strdh500/sony-strdh500
http://www.richersounds.com/products/hi-fi-separates/speakers/speaker-packages
I found with the all-in-one cinema 'boxes' that they struggled on inputs esp when adding a games console.
Posted : 05/01/2011 4:21 pm
Aus - you should be able to connect from the 3.5mm jack output from the TV to the jack input on the speaker driver/sub.
But double check your TV audio output and the speaker manufacturers site to be sure.
Posted : 05/01/2011 4:37 pm
I've just gone to 5.1 (well no .1 yet, but I don't really need a subwoofer because I've got big floorstanders), but for decades I used just stereo and it isn't really that far off for more or less every type of viewing. I'd say get a cheapo secondhand stereo amp (look out for a Cambridge or NAD or similar on ebay) and some medium sized speakers - drastically better than standard telly sound, plus just the job for radio and music.
Posted : 05/01/2011 5:14 pm
Would this be a good time to mention (again) that I'm selling an amp? Yamaha RX-V595, open to sensible offers. Better than Winamp in the llama's arse whipping stakes.
Posted : 05/01/2011 5:31 pm
