TV Aerial question ...
[Closed] TV Aerial question - how many cables can I run of one aerial?
9 Users
Currently I have a chimney mounted aerial and two TV co-axial cables running off it. I get a great signal.
If I add two more cables to the aerial will the signal strength reduce?
No more than 2 tv's would ever be simultaneously!
Thanks!
Posted : 12/10/2011 11:19 am
We had one fitted last week znd where told u can only run to cables off one arial
Posted : 12/10/2011 11:23 am
The signal strength will obviously reduce for every cable added.
But with a distribution amp you could split it - preferably mounted at the aerial end.
Posted : 12/10/2011 11:32 am
Try it and see, if the picture quality drops get a booster box.
Posted : 12/10/2011 11:33 am
Will the signal strength only reduce if the TV's are on? Like I said, currently with two TV's on the signal is fine. I can't imagine adding a cable will reduce the signal if it's not used?
Re. sucking and seeing would mean two trips by the engineer if the signal is shite, I don't have roof ladders so I won't be doing it myself.
Posted : 12/10/2011 11:37 am
You could split it inside the house, is what they mean. No engineers necessary.
Posted : 12/10/2011 12:32 pm
Depending on where the cable runs just now could you pull one of the cables into your loft (presuming you have one) and wire it into a splitter amp then run 3 cables from the amp 1 back to where the cable ran preiously and 2 to the 2 new TV points.
Posted : 12/10/2011 12:39 pm
 mos
As the signal is now digital, surely splitting it shouldn't be as much of an issue? It's either 1 or 0!
Posted : 12/10/2011 12:43 pm
Unless it's on a conveyor belt.
Posted : 12/10/2011 12:45 pm
aha, some great feedback there, many thanks!
I'll look at the loft option, makes sense to me.
Posted : 12/10/2011 1:07 pm
depending on you signal strength and the length/condition of you existing cabling you will need either a splitter or ha masthead amp/ power supply and a splitter. (so I'd try just the splitter first).
Note the masthead amp is just to overcome the losses in your distribution system, and is no substitute for a good aerial.
Posted : 12/10/2011 5:50 pm
