Today's Excel ...
[Closed] Today's Excel question
4 Users
What I want to do is have a running total (on a separate sheet) of numbers in a column. All values are 1 or 0; I want the total to reset when there's a zero.
Any thoughts how?
Ta
Andy
Posted : 30/01/2012 5:26 pm
does your running total column run down the B column as if next to your numbers column in A?
In which case simply have code in B2 with list starting at A2:
=if(A2=0, 0, A2+B1)
Posted : 30/01/2012 5:28 pm
No - want to have the running total in a fixed position on another worksheet.
Andy
Posted : 30/01/2012 5:45 pm
what do you mean by reset?
Or do you mean just to sum the 1s in a column until it gets to the first 0?
Posted : 30/01/2012 5:58 pm
Sorry - should have been clearer. What I want to do is total the 1's until a zero comes up, at which time I want the total reset to zero and then start adding up the ones again.
ie:
1 (total=1)
1 1 (2)
1 1 0 (0)
1 1 0 1 (1)
1 1 0 1 0 (0)
1 1 0 1 0 1 (1)
and so on.
Andy
Posted : 30/01/2012 6:06 pm
so in which is your total calculation going to be?
And in which cells are your number sequences?
Do the number sequences run along rows as in your post up there ^?
Do they have the same number of entries in each row?
Posted : 30/01/2012 6:30 pm
Assuming the 0s and 1s are in their own columns then try this in cell a2 on sheet 2:
=IF((SUM(Sheet1!A2:Z2))=(SUM(Sheet1!A1:Z1)),0,IF(MOD((SUM(Sheet1!A2:Z2)),2)=0,A1+1,0))
You'll have to complete the first cell A1 manually on sheet 2 e.g. 1.
I'm gonna guess this is gambling related?
Edit probably need another if maybe an and if it's odd, somewhere.
Posted : 30/01/2012 7:10 pm
 poly
depending exactly the format of your data - I would suggest you use the fact that multiplying by 0 and 1 has the desired effect...
...but without seeing exactly how your data is laid out its difficult to be more specific.
Posted : 31/01/2012 1:05 am
I seem to have got it to work using VLOOKUP and an array formula to match today's date to a running total in a second column.
Thanks all!
Andy
Posted : 31/01/2012 12:48 pm
