Trying to wire up a TV to DVD unit which stored in another room, the wall between them is solid brick & I don't want to drill a masive hole!
Is there such a thing as a scart lead with a pull apart small plug adapter that you could feed through a small hole?
Blanked with google so far!
Take the scart head off, put the wire through, then reattach scart head.
Or use a much smaller HDMI lead if it's an option?
Why not just use a scart to phonos & then (if req) a scart to phono adaptor?
44mm core bit and a tin of expanding foam
exactly how far apart are the TV & DVD? You say they're in separate rooms, but are they on opposite sides of the party wall, or further apart than that?
Really begs the question "why?" though
uplink +1
Had exactly the same problem. I couldn't find a through the wall lead which did replicate all the pins. In the end I got the scart lead with the lowest profile plugs and a damn great masonry bit...
I did this to link a sky+ box to another room
How pins of the pins were you using?
[b]uplink[/b] I know that now.... but I wasn't convinced by the leads I saw advertised which usually only did 9.
would be much easier if sky boxes had had multiple HDMI outs. And surely HDMI-HDMI is the solution here. DVD players cost nothing these days.
Buy a soldering iron any cutters/strippers and just re-wire the head at the other side.
Thanks for the advice found these now that will do the job[url= http://wap.ebay.co.uk/Pages/ViewItem.aspx?aid=130424589068&sv=Through%20wall%20scart&emvcc=0 ]http://wap.ebay.co.uk/Pages/ViewItem.aspx?aid=130424589068&sv=Through%20wall%20scart&emvcc=0[/url]
