Thread tapping – ne...
[Closed] Thread tapping – next size up from this hole
8 Users
I’ve picked up a Record 4 1/2 plane. It’s missing the handle toe screw. Some googling tells me it’s a 7/32? 20tpi screw, which are very hard to get hold of (impossible so far). (I tried a frog screw but they are too short). So the solution is to tap out the hole.
Would I be better tapping to 1/4? UNC (20 tpi) or use 6 mm (which works out at 25.4 tpi)?
Many thanks in advance
Posted : 22/03/2017 12:35 pm
If you have to buy the tap, you'll probably find that the metric one will be cheaper.
Posted : 22/03/2017 12:37 pm
All the various parts for these are usually available on eBay. No idea on cost but have you had a look there for a start?
Posted : 22/03/2017 1:01 pm
https://www.ebay.co.uk/itm/122324917519
For the front handle
Posted : 22/03/2017 1:02 pm
Nope, this is toe screw on the rear handle. It's a little screw in front of the main bolt. I've been looking for a couple of weeks no with no luck.
Posted : 22/03/2017 1:13 pm
7/32 x 25.4 = 5.55mm
tapping size for m6 = 5mm
you might wanna go bigger.
m8 x 1.25 - tapping size is 6.8mm. how deep is the hole?
Posted : 22/03/2017 1:18 pm
I'd go for 1/4 UNC. Easy job and minimal change.
Posted : 22/03/2017 1:23 pm
tapping size for 1/4" unc is still smaller than 5.55mm you wont have full thread
Posted : 22/03/2017 1:49 pm
What Jamie says. The Thread pitch of a M8 coarse (normal) thread is 1.25 mm, near the same as 20 tpi. you need to drill the old threads out with a new tapping drill (6.8 mm) then tap the threads in.
Posted : 22/03/2017 3:43 pm
Try a few carboots, should get a whole plane for a few quid (for parts)??
Posted : 22/03/2017 5:05 pm
Surely even buying this whole kit is cheaper than getting the correct drill and tap? Or as suggested a whole plane, at least this kit will give you shiny new knobs and screws all round.
https://www.ebay.co.uk/itm/192085796899
Posted : 22/03/2017 5:54 pm
If you are in Essex I'll do it for you i have a million m8 bolts too
Posted : 22/03/2017 5:58 pm
Stick a 5mm drill down and go with the 1/4 20 unc there will only be a few thou of the 7/32 thread left and the tap will more than likely pick up on the original 20 tpi. Any local Engineering company will lend you a tap if they are half decent and someone there would probably tap it out for you, I certainly would if you need it doing
Posted : 22/03/2017 6:11 pm
But its same pitch so the tap will deepen the existing grooves. That's what makes it the easy option.
Posted : 22/03/2017 6:34 pm
Right fair enough. I ain't got a 1/4 20tpi tap or even any 1/4unc bolts! Or even a 1/2" spanner...
Posted : 22/03/2017 6:48 pm
I like Nick and Smith's logic. I've got done taps so that isn't an issue.
Many thanks!
Posted : 22/03/2017 8:22 pm
