Thermostat housing ...
[Closed] Thermostat housing - Ford Focus
3 Users
I have a 54 plate and it needs a new one of these. The Ford garage has one but I can't get over there by the time they close. Halfords have a Circoli one: Is this likely to be any good?
Posted : 27/09/2014 10:52 am
Just get it - they are std aftermarket housing - very common problem to fix - hence Halfords in stock.
Posted : 27/09/2014 11:01 am
That's kinda what I thought, but at £40 the part is significantly cheaper than Ford. I appreciate that manufacturer parts are usually expensive, but I just begs the question: Is the Halfords part poor quality and likely to fail?
Posted : 27/09/2014 11:07 am
The Ford one only lasted 10 years - tbh plastic thermostat housings are a bit rubbish - my brother had an automatic Mondeo - for which the specific plastic housing was completely unavailable from Ford or anybody else ...
It will do the job - likely for the rest of the life of the car .
You could google tosee if there are any reports of problems with Circoli housings on your model of Focus - and go from there
Posted : 27/09/2014 11:19 am
It turned out that £40 was just for one part. In total, it cost me around £87 from Euro car parts, plus coolant.
Posted : 28/09/2014 7:57 am
I did this job on my Focus. I just got the housing from Ford for about £75 or so. I was not impressed with the design of the housing with it being made out of what felt like cheap plastic and the guy on the parts desk admitted it was a crap design. I guess its a once in an ownership sort of job so not that much of an issue ultimately. I seem to remember that yo will probably need some jubilee clips too as the hose clips that were there were some sort of crimped ones which I had to cut to remove. Also small hands and a whist with an extra joint will come in handy.
Posted : 28/09/2014 8:50 am
Fitted the parts yesterday, or at least my Dad did. It's a tight and fiddley job, but not that difficult. We managed to re-use the hose clips using some adjustable pliers (Ford use a special tool).
I'll keep an eye on the coolant levels over the next few days to make sure all is good. I suspect it will need topping up.
Posted : 28/09/2014 9:16 am
