The Electric Car Th...
The Electric Car Thread
molgrips
I like the tips – I do always leave my keys in the exact same place for that reason but a glow in the dark bit might be good. Torches also.
Thanks for taking it in the spirit intended 👍
Posted : 08/02/2024 12:38 pm
Nightlight torch, always charging, normal mode is nightlight, pick it up and it switches to torch.
Posted : 08/02/2024 12:41 pm
They ought to put sprinklers inside dishwashers.  There's already a water supply, just run some hose around it with little plastic sections that melt when it warms up and spray water.  Of course, it's an electrical fire, but make sure there are enough earthing points and fuses and you'd be fine.
Posted : 08/02/2024 12:47 pm
Isn't that how they work anyway???
Posted : 08/02/2024 1:26 pm
Tip: do not allow people in your house to leave piles of shit on the stairs, you cannot see it through the smoke
Tip 3 - have a plan on where everyone assembles outside (sisters bil died 10 days after going back in his house looking for his daughter who was actually safe in the back garden)
Posted : 08/02/2024 1:38 pm
Not in the casings... presumably that's where the fires start because I'm sure it's not your dishes and leftover bits of pasta catching fire.
Posted : 08/02/2024 1:39 pm
Here you go. Plugged in the car to my Ohme at 1700. Told the charger I wanted 90% by 0400 and it gives me cheap electricity all evening.
IMG_0014
Posted : 08/02/2024 1:53 pm
My average electricity unit cost last month was 12.5p, running a 4 bed family house, with 2EVs on Intelligent Octopus and a wfh wife.
Ive set the kitchen electric ufh to come on for 3 hrs 0230-0530 daily during the cheap rate too, which warms up the house before we get up and keeps the dogs very happy indeed!
Posted : 08/02/2024 1:59 pm
It doesn't always do that - only when there's plenty of renewable energy. I've had it just say 'nope' when I've asked for more than can be delivered in the off-peak period.
Anyway - I may have to rethink the caravan towing idea. The Caravan Club have done tests on current cars, and most of them are only doing 45% of their range. I was hoping it would be a little more than half, as per my diesel experience.  What Car have tested some cars at only 80 miles - which is rubbish. That said, they did test each car with a van weighing 85% of its kerb weight so heavier cars came off worse.  They mention one car that was tested with a 1900kg caravan (huge) and a 1300kg caravan and that increased the towing range by 27%.
I know you'll all think I am mad, but I would like the option to have only one car, and I would like it to be electric. With current prices we could swap the two current cars for an Ioniq 5 long range and come out better off each month.
Posted : 08/02/2024 3:20 pm
Mine has never said no. Maybe because IO can’t talk to my car, it has to just take my word for it.
Posted : 08/02/2024 3:34 pm
I drive an Ioniq 5, and it’s pretty inefficient as EVs go, so I’d imagine it would lose less range than one of the higher efficiency ones like a M3
Posted : 08/02/2024 3:38 pm
 mert
What are you towing? Though you had a small caravan, 12-1300 kilos?
My current and previous diesels get about a 25-30% reduction towing a 1150 kilo caravan (straight I4 turbo at 330Nm and the new I4 turbo mild hybrid at 420Nm)
The petrol before that (only 250Nm) saw a ~50% reduction though, which is one reason i got rid of it and didn't replace with another petrol!
Posted : 08/02/2024 3:55 pm
Same for mine - Neither IO or the charger know the actual state of charge of the car, they just have to believe me when I say it needs 100% adding
Posted : 08/02/2024 3:57 pm
Current van is 1280 or something.  My current car gets about 56 ish solo and 27 hitched up, the Passat was about 60/31 ish.
I could handle 150 miles of towing range, which is around 50% of the WTLP of an Ioniq 5, but 100 miles is a bit annoying.  That said, with the charging speeds we discussed the other day, it might not be too bad.  Then again, in Mid Wales there aren't many motorway services so you might end up messing about like leaving your caravan in a lay by and going back for a charger.
Posted : 08/02/2024 3:58 pm
Regarding IO, I think you have to be able to talk to either the car or the charger no? Otherwise you're just on Octopus Go?  My charger occasionally fails to connect to the crappy Nissan systems and it assumes I need a full charge.
Posted : 08/02/2024 4:00 pm
I think you have to be able to talk to either the car or the charger no? Otherwise you’re just on Octopus Go?
yep thats right, in my case IO talks to the charger, but the charger hasnt a clue on the state of charge of the car, so I just tell the charger that it needs to add 100% and it has to believe me. So IO always schedules about 11 hours of cheap electric - the car doesnt take 11 hours worth of charging, it takes what it needs (usually about 50%)
Posted : 08/02/2024 4:11 pm
So about half as efficient. Similar drop in efficiency to electric then?
Obviously the overall range of the ICE vehicle is much longer in the first place which negates this loss somewhat but interesting that your real world figures don’t represent the 25-35% reduction that others are quoting.
Posted : 08/02/2024 4:32 pm
It seems to depend mostly on the aerodynamics rather than the weight.  My first van had a stupid little spoiler flick on the back; the next one was rounded, and I gained about 2mpg.
Also I tow with a car, not an SUV or van, so it's more aero to begin with and the addition of the caravan makes a much bigger difference.  In a previous discussion towed their caravan using a van and said that their MPG hardly changed - I think that was also quoted by a Range Rover driver as well.
Posted : 08/02/2024 4:37 pm
 mert
Jesus, Just checked my last journey with the caravan and a similar trip a couple of weeks before. 5.1l/100 without and 7 on the nail with... So 57 and 40 mpg.
Posted : 08/02/2024 4:38 pm
What caravan is that?
Posted : 08/02/2024 4:42 pm
What car/caravan?
The trip computer in my Passat was honest, it told no fibs unlike some seem to. Also, when we tow it's with two large kids in the back, bikes on the roof and loads of stuff.
Posted : 08/02/2024 4:43 pm
Have a look on the Ioniq forum. Theres bound to be some caravan towers on there. The other great thing for an Ioniq 5 camping ( or any if it’s siblings) is the Vehicle to Load option, allowing you to use the big battery for camping power.
Posted : 08/02/2024 6:13 pm
 5lab
Tip 2: put a glow in the dark keychain on a set of housekeys and attach a small torch. I actually knew exactly where my keys were, yet still couldn’t find them!!
you guys lock yourself into a building at night? Our front door is locked but both it and the back door needs no key to re-open whenever needed
Posted : 08/02/2024 8:19 pm
Deadlocks. A locksmith showed us how easy it is to get something through the letter box and pull down the handle, after my son shut the front door before any of us had picked up a key. Front door gets deadlocked when we leave, and at night.
Posted : 08/02/2024 10:55 pm
I almost rang a garage today about an Ioniq 5 long range 2WD.  Their advertised PCP deal for 15k miles a year would have worked out cheaper than us running the current 2 cars by about £100/m.  We may just need a second car for another month or two though, which stopped me.  According to the blurb it had a towbar already too.
Posted : 08/02/2024 11:00 pm
Mrs g-d has just sent me details of their new salary sacrifice ev/hybrid scheme.
Having failed to jump out of my SMax for a nice auto estate in the autumn my brain is ticking this over...
Now I'm pondering 300mile WLTP range Golf ish sized car.
I do 180-200 miles of mixed commute type driving/week = 1 charge/week (+maybe a top up for the Tuesday to go off biking).  Each round trip about 20 miles each way split very roughly suburbia 3 miles, motorway 13 miles, urban 4 miles.
Install home charger and spend some time working out tariffs for cheap overnight leccy and this is
It'll also handle 100miles to and from a meeting relatively easily.
This is suddenly feeling like prime EV territory.
Big journeys and trailer lugging is still looking like an existing ICE car job but that would slow the mileage accumulation and wear and tear on the older car.
Downside of this strategy is all the big trips are in the "old banger".
OR
Passat GTE or similar plug in hybrid that can tow a bit
30 or so miles EV range?
Gets me to work, but not home again, on a charge or use hybrid mode for the motorway bit and EV round town.
Seems to do about 45-55mpg mixed use according to reviews.  Not amazing but at least it's not stinky diesel like the current big car.  🫤
Main upside is the big trip car is the "nice" car but we're losing a lot of the EV running costs wins to get that.  Is this in fact the worst combination of all other than for urban emissions?
I still don't think we can manage the tow car being a pure EV.  There are a narrow set of circumstances that I just can't figure out how we could do what we needed to even with a really expensive big one.
Am I roughly barking up the right tree on this?
Posted : 09/02/2024 12:15 am
 5lab
Some of he newer phevs give a lot more range, prius (new one that isn't around yet is quick and gets great reviews) and RAV4 are both into the 40miles, I think the 2 series is 50ish? If there's no charging at work that might get you nearly all of your day to day driving on electric
Posted : 09/02/2024 12:23 am
Passat GTEs aren't really good for 30 miles of range, at least they weren't.  We looked at these, and the range wasn't enough to make it worthwhile for our usage.  The new Merc hybrids have a genuine 60 miles of range, and whilst the C class is spendy it's not that expensive next to a lot of EVs.
That new Prius is not going to be sold in the UK, apparently.
Posted : 09/02/2024 12:46 am
Thats what Toyota said originally, but they changed their mind. Its coming to the UK soon. It does actually look nice/stylish.
https://www.toyota.co.uk/new-cars/all-new-prius-plug-in-hybrid#:~:text=On%20sale%20from%20early%202024,embodies%20the%20spirit%20of%20progress.
Posted : 09/02/2024 8:44 am
Fantastic news. The US motoring press loved it.
Posted : 09/02/2024 9:01 am
Not so much what as where.  This is the most common one (although it now has 4 additional storage tubes mounted). It weighs about 500kg with the little boats and weekend kit and probably 600-650 with a week's gear or the bigger boats.
Screenshot_20240209-080233
Definitely not as aerodynamic as a caravan 😉 but quite a lot lighter.  A trip to Pwllheli was enough to knock 10mpg off the long term average (and I never reset that).
The issue is not so much what we tow but where we take it.  Weymouth (at 100 miles) was one example although I see Lidl now has fast chargers near the sailing academy 🙂 (I haven't looked for a while).
Last year's Topper Nationals at Pwllheli in North Wales would  definitely have caused us issues and we love Snowdonia and CYB but there are some holes in the fast charge network that I haven't worked out yet in the context of a 50% range drop for towing / bikes on roof.  Mainly because where there are decent chargers they seem to be centred in urban car parks that are not designed for trailers 🙂
Maybe I need more time with ZapMap (or something else?).
Posted : 09/02/2024 9:50 am
I do feel more positive than I might have done a year/few months ago.
Posted : 09/02/2024 9:52 am
 mert
What car/caravan?
Those figures are from the current car, a V60 B4 Diesel, prior to that a V60 D3 and a small 4 berth (4m long on an Al-ko chassis) plated at 1150kg i think.
My last two cars have been using dataloggers to gather data... So *pretty* accurate. I can even see torque request, injection volumes, pressures, ramps and timing!
Also, when we tow it’s with two large kids in the back, bikes on the roof and loads of stuff.
Kids aren't large, but it's usually 2 or 3 of them, plus some combination of bikes (random number between 2 and 5) and/or a 6m Canadian. (Have a rack on the front of the caravan for 2 bikes as well).
Posted : 09/02/2024 9:59 am
Kids aren’t large
Mine weigh as much as two adults, the oldest is 172cm and 85kg.  You are doing very well to get 40mpg with that lot.  I might have seen somewhere near that in the Passat with steady 50mph roads, but your average Welsh A road involves lots of braking and accelerating usually.  Our caravan isn't small though, so perhaps your height is different?
@garagedweller - that trailer might have a higher drag coefficient than a caravan but it's got a much smaller frontal area.  I bet that would not drop your range anywhere near as much.  Also, at that weight you have a much wider choice of car.  A Hyundai Kona for example can tow 750kg and I would not be at all surprised if you could get 150 miles from the longer range one.  Those figures in the test I linked to earlier are for big heavy caravans in winter.  The issue you have is that it's rather hard to test this theory out!
Also, re North Wales, they have put more chargers in recently.  Of course, they are still rare, but not quite as rare 🙂 then you also have the issue that you have to un-hitch. Still, for me, I tow a few times a year and I'm prepared to put up with it for the benefits the rest of the time.
Posted : 09/02/2024 10:55 am
For the campers / caravanners amongst us I’d recommend toughleads.co.uk ModulEV system.
I got them to make me up a 15m IP65 13a extension lead with an interchangeable plug on the other end that is thin enough to fit through a letterbox. I have a 13a plug that I can use as a normal extension lead and a CEE 16a T-connecter that I can use to tap off the caravan site supply so I can use the granny charger without plugging it into the caravan itself and potentially overheating whilst still powering the caravan.
I use the extension quite often with the V2L to power stuff from the car.
https://toughleads.co.uk/collections/ev-electric-vehicle-extension-leads/products/modulev
Posted : 09/02/2024 11:46 am
I thought I'd try and get a handle on the battery health/capacity of my 2 yr old e208. Nominally 50kWh, but actually 46.3 kWh usable I believe. I noted battery start and finish %, along with distance and m/kWh from the trip computer to work out kWh used per 1%. Do you think this is a valid way to estimate battery capacity, or am I missing a crucial factor?
EV1
I also tried it the other way round based, on battery % before and after charging + kWh added by charger. This seemed to give better than possible numbers, presumably as the amount of energy the charger has supplied is more than than is actually added to the battery as it's not an 100% efficient process. I'm not sure if I'm missing a similar factor from my 'energy out' method?
EV2
Digging out the figures was part prompted by the latest Harry's Garage video where, among other things, he says that he thinks it's scandalous that battery health is not displayed by the car as it's an equally as important factor as the mileage of the car when looking at buying a used EV.
Posted : 09/02/2024 2:45 pm
You are missing a few factors I think.
- The capacity of the battery varies by temperature - a warmer battery gives up more kWhs.
- The percentage displayed on the dash is not the true battery state of charge, there's always some headroom
- charging is not 100% efficient and that depends on temperature as well.
Posted : 09/02/2024 2:50 pm
I'm assuming that added % also comes form the charger, not the car.  There will be losses.  It's usually about 75-99% efficient.  Most are toward the upper end, but even at 97%, you'd still be losing 1.2kWh.
Posted : 09/02/2024 2:58 pm
This raises a point that's been bugging me for a while. It's no wonder residuals are so poor when there is no easy way on most cars to display a battery health %.
I get why the manufacturers don't want it to be easy to see, but it is flipping annoying as a used car buyer.
I seem to recall that you can read the battery health using a modded OBD dongle on PSA cars. I know some dealers are able to give you a diagnostic readout showing the health percentage if you ask for it too (for a fee, natch).
Posted : 09/02/2024 3:22 pm
It’s no wonder residuals are so poor when there is no easy way on most cars to display a battery health %.
There is on many cars.
Also I don't know what you mean by residual value being 'so poor'.  They were still more expensive than equivalent ICEs when I was buying - although the specific car I bought was very cheap, ended up about the same.
Posted : 09/02/2024 3:35 pm
molgrips
Also I don’t know what you mean by residual value being ‘so poor’. They were still more expensive than equivalent ICEs when I was buying – although the specific car I bought was very cheap, ended up about the same.
I think the word 'many' is doing quite a lot of heavy lifting there. 🙂 The Leaf...erm...struggling now.
I mean we're talking about one which makes it difficult five posts above this!
I certainly couldn't see it easily available on any of the EVs I've been in (Tesla 3 - without a 24 hour diagnostic test at least, Kia eNiro, MG 5, some others i've forgotten). In fact I don't recall ever seeing it readily displayed except on an old Leaf.
Posted : 09/02/2024 3:59 pm
 DrP
I never thought of that..
The leaf has it displayed on a standard info setting..
The Polestar.. No idea!
On another note..ohme charger installed this am.. Octopus go switched to intelligent go.. And the Leaf is now charging at 7.5p/kWh, and hence the rest of the house is too... Nice!
DrP
Posted : 09/02/2024 5:01 pm
I hope you have better luck with the Ohme app than I have, DrP.
I have a Kia EV6 (77.4kWh battery) and the Home Home Pro. Worked great for about 3 weeks but then the app kept failing to recognise the car when I plugged it in and assumed the battery was at 0%. Contacted Ohme and they sent me a 'fix':
"I would advise refreshing the API connection between Ohme and Kia.
You can do this by following these steps:
1. Make sure the charger is unplugged. This is always important when making any changes in the app.
2. Log out of your Kia app and log back in. Avoid using biometric login such as facial or finger recognition and manually type in your credentials to confirm they are correct.
3. In the Ohme app go to the 'Manage My EV' section and tap 'Switch Car'.
4. Select a different make and model to your own car. Plug the charger into the car for about 30 seconds to save this change.
5. Unplug the charger and go back into the Ohme app, 'Manage My EV section'.
6. Tap 'Switch Car' and this time select Kia again and when prompted to, log in with your Kia account credentials.
7. Once you have successfully changed the car, you should be returned to the 'Manage my EV' section with the battery status showing on the right side of the car image."
That worked for a month or so until an Ohme app update about 3 weeks ago. Now if I try the 'fix' the app things I have a Kia EV9, which has a 100kWh battery.
Contacted Home again and their response this time was:
"Unfortunately, we are still experiencing some issues with the API connection for Kia.
Our Product team is currently investigating this issue and will look to resolve this as soon as possible.
As an Ohme Labs feature, communication directly through your vehicle (via API) is still in development. As a result, it may not work as intended from time to time.
For the moment you would need to disconnect the API link (by clicking Continue Without Account after selecting your car make) and then adjust your charge schedule slightly to 'add' a certain amount of charge rather than meeting a 'target'.
We're sorry for the inconvenience this may cause."
I read that as meaning they haven't got a clue why the app has screwed up.
It worked absolutely fine when I got the car last September but subsequent updates have screwed it up.
It's not all bad though. The app can still tell the time and I get the Intelligent Octopus Go 7.5p/kWh tariff overnight.
Posted : 09/02/2024 5:26 pm
 DrP
Sounds annoying...
So we've got 2 EVs ..leaf and polestar...
I'm the ohme app I've just put the car as the polestar...
I guess it'll just keep pumping out electrons, and once either car is full, they'll stop it..
It seems to be charging the leaf even though the app has the polestar as the car...
DrP
Posted : 09/02/2024 5:47 pm
Saw the new Prius in Tokyo last month. Genuinely didn’t know what it was at first but it stuck out as it was a lovely looking car. Was quite stunned when I saw the badge on the back. Even the car nut I was with said he thought it was a bonny motor!
Posted : 09/02/2024 5:50 pm
Page 124 / 235
