Synology NAS users....
[Closed] Synology NAS users...QuickConnect problems?
7 Users
 Kit
Hi, I just got my Synology NAS today (DS213j) and the QuickConnect service seems to be having a fit ("Oops...can't connect to QuickConnect server. Please try again later"). Does anyone else use this? Having a quick Google suggests it's pretty unreliable.
Posted : 26/08/2014 10:33 pm
I connect to mine - not sure of the model - using "DSM" (via browser) or "assistant" as a programme
not got quickconnect on my pc
Posted : 26/08/2014 10:47 pm
 Haze
Assume you're trying to connect remotely? Can be flakey at times.
If you're in range of the wireless use the NAS IP address to connect through your browser, assign a static one for mapping network connections.
Posted : 26/08/2014 10:56 pm
Oh, do you mean connecting via the www rather than local newtork ?
In that case, I'm oot*
*not competent
Posted : 26/08/2014 11:09 pm
 Kit
Aye, connecting through the web and the mobile apps. Connects fine over the local LAN using the IP address.
Posted : 26/08/2014 11:29 pm
 Haze
Have you checked the status at MyDS centre?
Ports forwarded etc. (assume this was sorted through the quick connect wizard)?
Posted : 26/08/2014 11:44 pm
I've never been able to connect from outside the network. Recently I discovered that Sky broadband's router prevents this. Ho hum.
Posted : 27/08/2014 12:32 pm
[quote=duntmatter said]I've never been able to connect from outside the network. Recently I discovered that Sky broadband's router prevents this. Ho hum.
But you can configure it to allow the connection.
I use a Dynamic DNS service (no-ip.com) to allow me to connect using a domain name, then setup port forwarding on my router to send all port 5000 traffic to the NAS LAN address. I use a reserved IP address for the NAS on the LAN so that this will work.
Posted : 27/08/2014 12:34 pm
I would love to access my synology NAS at work but I have no idea what allthepies is talking about!!!!!
Posted : 27/08/2014 3:34 pm
Check your router's port mapping and firewall settings. Quickconnect and synology's DNS service should do the internet hard work.
Can you connect using the domain name rather than the quick connect ID?
You might prefer to redirect services to [url= https://www.synology.com/en-us/support/tutorials/464 ]https[/url] and make a security certificate for the disk station. This should encrypt your login and data transactions between your remote browser and the disk station.
[url= http://helpforum.sky.com/t5/Sky-Broadband/Sky-Hub-How-to-Configure-Port-Forwarding/ta-p/707150 ]Sky port mapping[/url]
[url= https://www.synology.com/support/faq/299 ]Synology port list[/url] although this wasn't connecting just now
[url= https://www.synology.com/en-uk/support/tutorials/584 ]Synology DNS[/url] although this wasn't connecting just now
Posted : 28/08/2014 6:30 am
