STW posts - how to ...
[Closed] STW posts - how to use icons etc..
13 Users
How do I use things like underline, bold, URL etc when posting on this forum?
The appropriate icons on the toolbar just give me a text transcript of the command e.g. [b][u] rather than changing the text.
Is there something I need 'enable' or an application I need to download?
thanks
Posted : 17/12/2009 9:51 am
Press the one you want, type the text and press it again.
Posted : 17/12/2009 9:54 am
Press it once before the text you want to change, then press again after it.
[b]as [/b]I understand it for any hypertext mark up you need to select the function ( hit the button once ) type the text you want and then hit the button again to [u] "close" [/u] the function
or hey... [i]highlight [/i]the text and then hit the function button once
Posted : 17/12/2009 9:55 am
When you edit your post, you only see the tags (the commands in the square brackets). When you post it, it changes it (it's not WYSIWYG).
testing
[u]thanks[/u][b]more test[/b] 😯
hello
Posted : 17/12/2009 9:57 am
Wrong way round.
Posted : 17/12/2009 9:58 am
almost there... somehow you got your quote buttons backwards. = end quote
Posted : 17/12/2009 9:59 am
= end quote
Posted : 17/12/2009 10:00 am
You can just highlight the text & press the relevant button, it'll do the formatting for you
Posted : 17/12/2009 10:02 am
Or type in the [s]words[/s] then [b]highlight[/b] the[i][b] ones[/b][/i] you want to change and press just the once.
[b]Uplink[/b] [u]beat[/u] [i]me[/i] [i][b]to[/b][/i] [s]it[/s]
bold[b] [b]bold[/b]
Posted : 17/12/2009 10:03 am
[s]fail [/s]
 Pook
[b]it's[/b] [i]a[/i] [u][b]mine[/u][/b]field
isn't it?
Posted : 17/12/2009 10:04 am
If you have a crappy browser, that doesn't work.
Also if you select the text you want to alter then press the appropriate button it wraps the text with the right bit of code.
Edit: Uplink also beat me to it.
Posted : 17/12/2009 10:06 am
yep, doesn't work for me if you highlight the text and press once..which is what I'd been doing for ages. The prefixing and suffixing works fine.
Thanks very much for help guys 😀
Posted : 17/12/2009 10:07 am
There is a "Preview Post" button that lets you see what it will look like without damaging your reputation.
Posted : 17/12/2009 10:13 am
[colour=red]of course there are other things you can do[/colour];)
edit but not on this forum? 😳
[color=red]of course it is us spelling![/color]
Posted : 17/12/2009 10:27 am
If only you knew how to do it eh? 😀
color doesn't have a "U" in it in internet world
Posted : 17/12/2009 10:28 am
[color=red]of course there are other things you can do[/color]
you need to be american for that to work
Posted : 17/12/2009 10:29 am
thanks (u)pling i just got wot i did wrong!
Posted : 17/12/2009 10:30 am
[color=blue]we invented the internet after all , so we chose the spelling[/color]
(never mind that Tim Berners Lee fellow.
Posted : 17/12/2009 10:32 am
[size=1]There[/size] [size=2]are[/size] [size=3]some[/size] [size=4]other[/size] [size=5]undocumented[/size] [size=6]ones[/size] 😀
Posted : 17/12/2009 12:14 pm
